HP Envy M6
What are you asking,?
who can fix it (any PC shop on earth)
or how can you diagnosis it and how to test PC?
what is the question?
yes, all do that , eventually. all do.
HP Envy M6
M6-nnnnn why not tell the helper, what nnnnnn is,, the full model matters. as does the unstated OS? Windows 7?
a laptop no less, my guess.
m6-1000 is 5 years old (i tossed 2 dice to get that, model.)
here is the list, and page links on tests.
we know the PC processes and the screen works.
but resets, reboots, or even BSOD's
this rebooting usually progresses to dead black screens.
and the cause is same, leaving out bad screens.
see the stripping tests here, for the hard nut cases.
http://www.pcdied.com/black-screen.html#Laptop
the hdd tests are here.
a bad HDD self corrupts the OS, and then resets.
HP will even on newer machines put you on the F11 recover page any time the pc does that.
i do the linux tests. booted from CD.(or usb stick)
http://www.pcdied.com/brick-dead.html
SOURCE: laptop will not boot, nor will keyboard respond-- hp dv8000
There is a class action lawsuit currently being initiated against HP for this issue. The Complaint alleges that HP misrepresented and concealed material facts regarding certain laptops including a design defect, which causes the power jacks of the laptops to fail.
Sign up here:
http://www.sfmslaw.com/pages/cases.php?id=300
SOURCE: LG viewty switching itself off
Try changing "network settings" to "GSM only" instead of "automatic".
SOURCE: I have an HP dv6000 laptop computer, and, starting
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
SOURCE: Envy Touch freezing and or shutting off
Hi, When a phone freezes, it caused by virus or unwanted applications on
your phone.it needs to be flashed, you can use the link to learn more
and how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take
care.
SOURCE: i have a hp envy m6 cant find the control pannel
press window key and r key together, this is run command , a dialog box will open then simply type control panel in the box and u r done . control panel will open automatically.
