Question about Weber Genesis S-320 Propane Grill
The new propane tank is not sending gas to be ignited even though it is hooked up properly.
    President:
  • 1,273 Answers
Hello.
Troubleshooting a grill isn't difficult. Close the propane outlet valve at the tank. Disconnect the tank, and get it out into the open.. Crack open the valve and make sure that you have a burst of gas pressure. (Careful here, you don't want to have a bad day. Point the opening away from you.). If you are sure that you have a good cylinder/gas and valve, it may be your regulator. Hook it back up and try for gas at each valve. Leave the lid up/open. You should be able to hear it if it is coming through one of your valves. (I should caution call here again.... Open only one valve at a time, check for sound, and close it. Wait two minutes, and try the next valve). You don't want to inadverdantly create a pocket of gas that could flash on you, if it found a source of ignition...let it dissipate, then try the next one, etc..Don't try any one valve for more than 10 seconds. If you are unsure that you heard something, please , follow the two minute rule. Should it be your regulator, replacements are readily available at "home hardware" type stores (Lowe's, H/Depot, etc.) and are easily replaced.
Hope that this was helpful to you.
Best regards --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
Hooked up new bottle,will not get hot,low flame
Turn off burners. Turn off gas. Disconnect regulator from propane tank. Reconnect regulator. Turn on burners Turn off burners. Turn on propane SLOWLY. Turn on burner and ignite.
Aug 18, 2014 | Weber Genesis E-310 Gas Grill
I have a KitchenAid 6 burner range / model # KGCP467. It does not appear as if it has ever been used. I bought the LP conversion kit. Replaced the burners and flipped over the plastic piece in the...
I would look at your pressure. My guess is it is too high. The cooktop is designed to run 10-14 iniches water column which equals .36 - .5 psi. If you were running higher than this you could have damaged components in the cooktop.
Apr 07, 2017 | KitchenAid Kitchen Ranges
Machine will not ignite...ignitor clicks...new battery...new fuel filter...new propane tank...cleaned machine...help!
is the propane hooked up correctly with the valve turned on, and verify that there is propane inside the tank as I have purchased new tanks that were empty. Hope this helps Tim
May 15, 2011 | Garden
Just hooked up new propane tank and grill won't ignite either with starter or matches
Turn gas tank off and disconnect from grill. Check burners to ensure there is no blockage and reconnect tank.Open gas tank slowly, some grills have a sensor to detect leaks and automatically shut off gas. Opening the tank fast can cause this safty device to falsely read the sudden gas flow as a leak. If you still can't light the grill check all fittings for a leak using soapy water.
Apr 28, 2010 | Kenmore 774 sq. in. Cooking Area Gas Grill...
The gas does not light
get a new unit dont play with propane it goes bang!!
Oct 31, 2009 | Reddy Heater RLP100 Portable Forced Air...
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Apr 27, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Grill won't start
The regulator on the gas feed line is not working properly. Take the regulator to a propane supplier and have the regulator checked.
Apr 25, 2009 | Grilling
Weber Genesis S-320 Propane Grill Logo
955 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
