Question about Airhead Water Sport
Need replacement tube for HO sports 'Whip II' 54" tube. The cover is in great shape but the tube is aging. I would like to buy the tube and get more use out of this towable.
2 Suggested Answers
  • 5 Answers
SOURCE: what is the best way to patch a small hole in a towable tube
Your local sporting goods store should carry a patch repair kit that should work perfectly.
Posted on Oct 19, 2009
Cam specs on a 1967 Pontiac 400, 335 hp
Firebird App. Pontiac Part # Duration @ .050 Degrees Int/Exh Adv Duration Degrees Int/Exh Lobe Center Degrees Int/Exh Lobe Separation Angle Overlap Cam Lift Int/Exh Gross Lift Int/Exh
(1.5:1 Ratio Rocker) Gross Lift Int/Exh
(1.65:1 Ratio Rocker) 1977 TA6.6 549431 274/289 62 .249/.270 .374/.406 .411/.446 1978 TA6.6 10003402 273/289 54 .270/.271 .406/.407 .446/.448 1979 TA6.6 10003402 274/298 55 .249/.270 .374/.406 .411/.446 1967 400, 1968 350, 1973-76 400 w/ AT 9779066(E) OEM 200/210 273/282 106/116 111.25 55 .272/.271 .408/.407 .449/.448 1967-68 400HO w/ MT 9779067(P) OEM 200/213 273/289 113.5 54 .272/.271 .408/.407 .449/.448 1968 400 HO MT & RA-I AT, 1969 350 HO MT, 1969 400 MT, 1970
RA-III MT/AT, 1971-72 455 HO MT 9779068(S)
OEM 212/225 288/302 113/118 116 63 .272/.271 .408/.407 .449/.448 1967 RA MT/AT, 1968 RA-I MT,
(Some 1969 GTO RA-III MT) 9785744 (H)
OEM 224/236 301/313 112/119 115 76 .272/.271 .408/.407 .449/.448 1968-70 RA-II & RA-IV MT/AT 9794041
(T) OEM 230/240 308/320 112/115 114 87 .313/.313 .470/.470 .516/.516 (Stock in RAIV)
Sep 20, 2017 | Pontiac Cars & Trucks
Changing transmission oil 1991 toy camry
OK auto. In that year the transmission fluid and differential fluid are not joined (although both are ATF), and have different drain plugs and fill points, so you have to identify them. First see here p 30 and p 54.
http://www.turboninjas.com/camry/ax1.pdf
Note the transmission (but not the diff) is filled through the dipstick tube. It is convenient to buy the ATF (Dexron II or similar) in a container with a tube in the cap which will do this easily, or use a long necked funnel. The final check of the correct fluid level in the transmission is done with the engine warm, and RUNNING. Move the shift lever right down to 1 or L, then back up to P, before checking.
Then in a car this age it is worth checking the diff fluid level is OK as well. You may even want to change it at the same time, which is a good idea. It should be level with the bottom edge of the fill hole. Also good is the have a hand pump like this
http://www.tsadvancedsynthetics.com/facts/g2039_banner_600px.jpg
Jan 25, 2013 | 1991 Toyota Camry
I have spotty reception on a handheld CB and was wondering if there is a testing procedure I can use to check the antenna and radio. I have a multimeter. It's a radio shack handheld with weather bands...
The antenna is your problem not much gain. Height is everything tx and rx. Although it would not compare to a conventional cb size negates performance. Seeing is believing in this case hearing get adapter to connect to standard coax of antenna. (PL259) to BNC Coax Adapter Radio Shack sells them. And dont ask or buy any radios there. They are hardly the radioshack of choice anymore.
  • If you put 4 watts into a four-foot antenna, you will get the same power out of that antenna as if you were putting 2 watts into a 102-inch whip.
  • If you put 4 watts into a 3-foot antenna you will get the same power out as if you were putting about 1.5 watts into a 102-inch whip.
  • If you put 4 watts into a 7.5 inch antenna on a hand held CB, it would put out as much power as a third of a watt into a 102-whip.
  • If you put 4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
  • If you put 4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
  • If you put 4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5 antenna.
May 21, 2011 | Cobra HH 38 WX 40-Channels Handheld CB...
Can you purchase a replacement inner tue for airhead mega slice?
Cynthia,
I have the same tube and looked around and found nothing... but luckily we were within 90 day warranty period and Kwik Tech sent me a replacement air bladder. If you're not so lucky you'll have to buy the whole thing again. But if you cover is in good shape you could always sell it on ebay and help offset the cost of the new tube. I would be willing to bid on it... my cover is getting worn. robloch at hotmail dot com Hope this helps.
Jul 15, 2010 | Kwik Tek Airhead Megaslice 4Rider Tapered...
What kind of code reader should I buy for a 1995 Pontiac Trans Sport car?
May depend on manufacturer date.All domestic vehicles after 96 are OBD II.Some late production 95 models are OBD II. if your diagnostic connector is rounded oval shape its OBD II. If the diagnostic connector is rectangled it's OBD.
Jun 17, 2010 | 1995 Pontiac Trans Sport
American standard toilet running
There should be two screws on top of the assembly to control the level of the water. One increases, the other decreases. But if the bulb has a horizontal split it will have to be replaced. It simply screws of and on the arm. The water hose clips to the drain tube and the water should be directed inside the tube.
Buy a bulb, and if nothing else, bend the arm down to decrease the level of the arm and bulb and consequently the water level.
Apr 24, 2009 | American Standard Lifetime 54 1/2 In. x 54...
Looking for an item - eye guard for scope on a gun
Pictures of the exact item along with any markings would help a great deal. Even a hand drawn sketch along with dimensions would help.
It sounds as if you may be describing a scope cover. One end cap is clear and the other end cap either clear or has a yellow tint.
Most all current covers have the end caps attached to each other using two stretchable thin bungee like cords although some do have a one piece rubber holding the end caps.
If this is what you are looking for any sport shop, most discount stores and such carry them.
I attached a picture of this type of cover.
Mar 22, 2017 | Tasco Golden Antler 3 - (9 x 40 mm)...
2000 Pontiac Grand Prix
you have to remove the alt bracket to pull the elbo out. the bracket is a pasage for coolant make sure you replace all four. theres another tube there. bee carfull when pulling them out they break realy easy good luck mark as fixya thanks
Sep 23, 2008 | 2000 Pontiac Grand Prix
Fungus in blue crt Akai rear projection
I don't have a pdf file for fungus in an akai, but you will need to remove the 2 tubes from the set, take off the cover for the reservoir and dump out the fluids and then fill them back up. you will then need to know how to do the convergence alignment after you put the tubes back in. This is a involved process, if you want to tackle this on your own let me know and we will see what we can do.
Tim Nolan
Sep 21, 2008 | Akai PT5492S 54" Rear Projection...
Replacement Canopy?
yes you can. of course on amazon, take a look here Amazon com Baby Jogger 2 canopy and chose some of them :)
I hope this was helpful, cheers
Aug 15, 2007 | Baby Jogger 2 Stroller
Water Sport Logo
613 people viewed this question
Top Airhead Water Sport Experts
Tom Chichester
Bill Boyd
Are you an Airhead Water Sport Expert? Answer questions, earn points and help others
