Question about Frigidaire FEF352 Electric Kitchen Range
The element on top of the stove stays on
The element (the coil that you cook on) on top of the stove stays on heating when the dial is on off.
  • Frigidaire Master
  • 3,361 Answers
Replace the switch for the bad element. It is stuck internally in the ON position.
Posted on Jul 30, 2009
THE COOKTOP WONT HEAT UP. BUT THE LIGHT ON THE CONTROL KNOB LIGHTS.
My first guess would be to check for proper connection at the wires from the stove body to that specific heating element.
Perhaps, lift-off or open the cook-top cover, and check the hook-up to the heating element itself.
How old is your stove, and is it fitted with the common "coil type" elements? Unless it's a very late, high-tech model, capable of checking its own wiring, the indicator light will illuminate regardless of an open circuit to the heating element because older models can't "see" or "know" whether something has come loose, so the indicator light will come on, and just sit there, cold and clueless.
Bon Apetit!!
Sep 20, 2016 | Jenn-Air JES9860 Electric Kitchen Range
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 | Cooktops
Cooking element on stove top goes on full heat,even when dial is set on low.
Electric, I presume. Disconnect power to stove, open backsplash, remove knob, replace control unit.(usually universal type). Available appliance repair shop. Careful with 220volt power!!!!
Sep 20, 2014 | Kitchen Ranges
Coil on stove top will not work properly
I think you will need a replacement heat element control unit, the module behind the knob on the controls panel. Take care if you intend to fit it yourself, make absolutely sure the stove main switch is off or the fuse pulled.
Jan 11, 2014 | Crosley CE35100AA Electric Kitchen Range
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
How to change cooking element on top of stove. is there a detail drawing and manual stove is 4 year old
Electric stove top? Is the element a coil or soild element? Or is it a glass top?
Feb 07, 2011 | Ovens
Kenmore stove model# 665.92024100 While cooking
Check and see if the broil element has shorted to ground.
Bonus
Apr 13, 2010 | Kenmore Ovens
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
Frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
Jun 26, 2008 | Kitchen Ranges
Frigidaire FEF352 Electric Kitchen Range Logo
144 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
