Question about DISH Network IR Remote Control
I have an extra remote that i want to add o my reciver so like that i can switch channels how can i program it?
    Problem Solver:
  • 13 Answers
The procedure is outlined in your manual.
On your receiver or main remote, press SYS INFO. See which channel your remote address is on. Then take the extra remote, press and hold down the SAT button. It will blink a few times then remain lit. Press the number that the remote address of the main remote is on the extra remote, then hit pound (bottom right button). You should be good to go.
Posted on Jul 30, 2009
TV will not switch channels. Manually nor remotely. Hook up another TV everything works.
Most TVs have a manual or auto-program feature to add or remove channels. It is possible that you have de-programmed all or most of the channels.
Connect TV to cable or antenna, enter the main menu and look for auto program feature.
Apr 11, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
I have an identical prestige remote which is not programed for my car iwould like to program it exatly like the one i now use so i can have a spare.
The programming procedure for Prestige/Pursuit remote is as follows:
First, locate the programming/valet switch. For newer model units the programming switch is located in the antenna, previous models have a push button LED (PBLED). Older models have a plain black push button, usually located near the driver's side kick panel (where your left foot would rest when driving).
After locating the programming switch; turn ignition on, press and release switch three (3) times,parking lights will flash once. This is channel 1 (lock button). Press lock button on remote. Parking lights flash once. Press and release switch one (1) time. Two flashes (channel 2). Press unlock button on remote. Press and release switch one (1) time. This is Channel 3 (trunk/remote starter), press the channel three button on remote. Repeat process for additional channels. Once you have programmed all available channels, turn ignition off to exit programming.
Jan 20, 2011 | Gmc Dodge Ford Reverse Back-up Sensor...
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
I have a Phillips PC7225 C121 ..I programmed it to a universal remote and went to menue.. it says Barker, Channel, Firmware ..I put it on channel but cant get to do anything after that...what do I do... I...
I need to add channel 66 to this tv and it only goes to channel 60.- the remote or the tv.?.
if remote doit mannuly on the tv.
if tv. .............................
Aug 06, 2009 | Televison & Video
Lost channels on a Sony KV-1972R
Go to menu and select add/delete channels. Then select 02, or 03. Some channels that are selected the numbers will show green, channels not locked in will be red.
Jan 18, 2009 | Televison & Video
Video mode
I went to add/delete channels in my menu on my symphonic and it let me scroll through the channels, make sure you have them all set to add (by pushing the volume buttons to make them light blue instead of purple)....after adding all of your channels (or just the one if you use dish) just power the tv off while on a channel and then power back on and you should have tv.
Jan 12, 2008 | Symphonic ST419E TV
Channel reception
What you need to do is go into the menu and go to channel programming and switch the TV tuning mode to cable and it will scan and recive all the channels. Good luck
Aug 20, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
DISH Network IR Remote Control Logo
150 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
