I have a Frigidaire model # FWS833AS1 the machine washs but doesnt spin the water out or even spin. It washs the cloths and thats it. I've tried turning the timer to different settings and the water does not go out.
    Scholar:
  • 87 Answers
I would check the lid switch. See if you hear a click when you close the lid. It sounds like that. Good luck.
Posted on Jul 30, 2009
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
Frigidaire FWS833AS1 - My washing machine recently stopped and wouldn't start spinning during the wash cycle.It will drain, just not spin. Also, it will do the wash and rinse cycles if set manually but...
Hi
Thanks for using FixYa. The smell might be due to burning of lid switch. If the washer isn't spinning then it might be dueto a Lid switch or due to a bad motor coupler. You can check for the lid switch& replace it--
First unplug the washing machine. Then remove the two screws that hold the top consolein place; these are located in back of the main console (where the dials are).Once removed, the entire console swivels back, exposing the wiresunderneath.
After this unplug the wiring harness that is connected to the washing machinetop flat surface. Now remove the two s-shaped brackets with a screwdriver byprying underneath. This will allow you to remove the main sheet metal framearound the washing machine. The lid switch assembly is located under the topconsole. Now, remove it and replace with the new assembly and put it backtogether.
Please look this schematicfor lid switch location(part # 50)--
You can buy the lid switch from this link--
Frigidaire FWS833AS1 Lid switch/assembly
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 16, 2009 | Frigidaire FWS833A Top Load Washer
I have a Frigidaire front loader washing machine. If there are only a few lightweight pieces of clothes, the water will not spin out. Also some of my clothes have spots on them after washing. What do I do?
For the odor, you might try running a cycle with a strong bleach solution (no clothes!!!). Leave the door open when not in use to air out.
Certain Frigidaire models will not spin out if the door switch is damaged or is defective.
Unplug the machine first before doing this!!
You can access the switch by removing the top (remove two screws from the back of the panel). To remove the switch, remove the two screws from the front of the machine where the door latches. Locate the switch and observe how the wires plug into it. Replace with new switch.
Jun 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
