Question about Whirlpool Duet GHW9150P Front Load Washer
Kepp getting a code f 02 then washer wont do
Keep getting a code f followed by 02 then washer wont do anything?
    Scholar:
  • 87 Answers
Open the bottom panel (3 screws on bottom) then you should see a drain clean-out. Unscrew that, there is probably something stuck in there. Have a pan ready to catch the water when you un-screw it. Good luck
Posted on Jul 30, 2009
My rear vents wont close 2003 montana
Remove rear seat belt bolt, remove upper rear panel, splice vent motor wires. Use 12 volt power supply to close. I used battery charger kepp closed so you can wash and keep rain and snow out.
Sep 25, 2012 | 2003 Pontiac Montana
I'M GETTING CODE F 02 IT WONT DRAIN OR DO ANYTHING
The F02 error code is for a long drain. (See image below).
Without a model number I am only able to provide you with generic instructions. I have included a set of illustrated instructions you will need to check drain pump filter. (See images below). Once the bottom panel is removed the drain pump filter cover looks like a gas cap. Remove that and then remove any foreign objects. If the drain pump is clear it probably needs to be replaced.
Apr 21, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F2 code is on, wont complete the spin cycle, try to reset with cancel and goes to 12 minutes, what is wrong with it?
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Keep in mind it is cold winter and the drains could be frozen or slow in the western hemisphere.
More here
Dec 20, 2010 | Kenmore Washing Machines
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I kepp getting eroor code 8001050f on my ps3 and i
yea its happening to everybody. look around on this site even. Hopefully sony will release something
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
I get the error code S02 on my Duet washer. It
02 is a slow drain,
yopu can check your pump
take off the back wall and hoses,, have towels ready
you will loose water,,
inspect the inside of the pump and all hoses
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F 02 Error Message
Hi!
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed.
Potential Causes
If still the problem persists then you need to replace the pump.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is displaying F 02 what do I do
"F02" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases, this is an indication of a clogged drain pump. All you need to do is clean the pump of any obstructions. Follow the advice in the link for instructions on how to clean and any other potential problems that may cause the problem to persist. If the error code does not go away after cleaning, you may have a damaged pump that requires replacement. NOTE: Make sure you UNPLUG the washer when servicing anything inside the unit.
If you have nay questions along the way, please let me know. I hope this helps you.
Jun 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting sud and F 02 in the display
The first thing you should check would be the type of soap you are using, in any front load washer you should always use HE (High Efficiency) and also a smaller amount than what you would normally use on a top load washer and this is due to the amount of water used also if you are looking for an owners manual you can download one by entering your make and model number in on this page. http://www.managemyhome.com/mmh/
Mar 25, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
