RCA Scenium HD50LPW162YX2 Power light on steady no lamp. When unplugged and plugged back in the power light flashes several times then goes back to steady. Have put new Phillips lamp in set still the same. I suspect maybe the fan is out and so lamp will not turn on.
    Brigadier General:
  • 8,619 Answers
Hi
It still sounds like a lamp. If the light blinks, then pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and then the light blinks steadily for one minute, possibility is that the lamp door may be open. Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn back on. The lamp should turn on. If still you face the same issue then it’s the fan which needs to be replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 30, 2009
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Tv just cuts off and the power button blinks 5 times and stops
According to the service manual the lamp needs to be replaced.
Hope this helps,
Skyassoc
Jul 18, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium 44" HD44LPW62
it does not sound good take it to tv shop intermitten shut down or dead sorry
Apr 03, 2009 | RCA Scenium D34W20 34" TV
RCA Scenium DLP
Usually that is an indication of a bad lamp. A lamp can be ordered and replaced yourself. Use the model number of the television to order the correct lamp.
Jan 30, 2009 | Televison & Video
RCA Scenium HTV won't turn on
My tv is about not even 3 years old, the bulb was already replaced once and now the tv will not turn on, we replaced the bulb again, but no change... The blue lights come on and flash but eventually turn off.
Jul 14, 2008 | RCA Scenium M50WH187 50" HDTV
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
"52" RCA Scenium DLP; No Picture and the buttons flash on and off
On the back of the TV, you'll find the Access door to your lamp. Unplug the TV from power, and remove the screw on the access panel. Inside you'll find 2 additional screws holding in the lamp housing assembly. Remove the screws, then the lamp assembly and visibly inpect it. You'll know if the lamp is defective, it will have obvious damage. If so replace with part # 260962, you can acquire this lamp for arround 100 dollars off ebay, or 262.00 direct from RCA.
Nov 09, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
Mar 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
