Televison & Video Logo
G
Gamaliel Viernes Posted on Dec 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the steps in programming rc 1024 to tv and cable box
Ron Reynolds
Level 3:
Master:
  • Master 433 Answers
  • Posted on Dec 15, 2017
Ron Reynolds
Master
Level 3:
Master:
Answers
433
Questions
0
Helped
171034
Points
1281
Look on the manufacturers website for support and programming.
1 Related Answer
Anonymous
  • Posted on Jul 25, 2008
SOURCE: how to program denon rc-1024 for tv dvd
how do i programme yhe remote?
Need code to an rca universl remote to control a magnavox tv
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Magnavox TV Codes: 006, 007, 010, 013, 016
2helpful
Program remote RC-1024
Expensive substitute...
http://remotes.com/remotes/servlet/rs?&smodel=VRDVD4000B&brand_pn=SANSUI_VRDVD4000B&o=c&o=c&a=Search&uid=0&m=rc1024&uuid=A12983029391101
Or look on eBay every once in awhile. Search "denon RC-1024 remote" and check the 'include description' box.
3helpful
2answers
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
  • TV-000
  • VCR-000
  • Cable Box-000
3helpful
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
Hughes remote codes
The only model of remote that i heard that it has pre-program Olevia code in it.. is the RC-64 or RC-64RB usually these remotes are coming with the new HD boxes..
Direct TV
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available… please call at 866-965-3842
1helpful
Remote control codes
  • TV-000
  • VCR-000
  • Cable Box-000
Find codes for device and brand below.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  3. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
RCA Codes for VCR
000,005,007,008,028
035,037,054,069
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
  • TV-000
  • VCR-000
  • Cable Box-000
3helpful
2answers
Rca systemlink3 remote control
DABII
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
