Question about Toshiba 42HP95 Television
My power light keeps blinking and the power will not come on.
  • Toshiba Master
  • 8,457 Answers
Ur power inverter board is dead.
U need a new one.
Posted on Sep 07, 2009
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Light low power on my Subaru 2000 Forester
I the light is blinking under strain then it sounds to me that the alternator is not producing enough voltage to feed the power to keep the battery fully charged
Jul 11, 2009 | 2000 Subaru Forester
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Power light keeps blinking and will not print
Just keep pressed the power light button until the light goes off.
Dec 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Nov 07, 2008 | HP DeskJet 6540 InkJet Printer
Power lights keep blinking
The power light indicates a problem (usually) with an internal problem. Usually there is a pattern to the light. (for example 3 blinks then a pause, 3 blinks then a pause etc.)
A service tech can use the code to help determine the problem.
Jan 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
455 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
