Question about GE Washing Machines
How do i replace the door boot seal on my front load washer?
  • kelly sweet Jul 30, 2009
    Thanks Scott but no its a GE.
    Thanks Woobie for the help and the "youtube" advice...I'll check it out.
    President:
  • 1,273 Answers
Hello. Feel around the edge of the bellows seal until you find a spring in the groove behind the face of the seal. Using a small screwdriver, lever it over the edge of the seal, and slowly work the ring over the seal face. Peel the seal off of the mounting flange, and roll it inside the drum. Remove the front of the washer, and remove the spring on the inner part of the seal. Replace the seal, amking sure that it is oriented in the same manner as the one you took off. Reassemble in the reverse order. There are a number of very good videos on YouTube. Type in "washing machine repair" and you'll fine different chapters in what amounts to a series on repair.....good stuff.
Hopes this is helpful to you. Best regards, --W/D-- please feel free to rate this carefully hand crafted answer! Thanx!
Posted on Jul 30, 2009
    Scholar:
  • 87 Answers
I'm assuming it's a kenmore, he, whirlpool. Take the top off, lower bottom panel, front panel with door off, 4 screws on the front, (also take out the ones 3 of em that hold in the door lock. Take the spring circle off that holds the front of the boot to the door. Enter the model number on the link below, and you can get to a exploded view of your unit to show you more. It's kind of a pain. I have did many but it usually takes me about 1/2 hour. good luck.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: front load washer
Hitchhiker, you don't have to remove the front of the washer. The original boot was glued in areas around the door. They came out with a new design because of water leakage on the bottom. The new kit, part number 5303937187 comes with a spring that holds it on to the panel. You can do one or two things, if you don't have the leaking problem, glue the boot back on. Or you can order the new kit, it comes with instructions and replace the whole boot. Check it out, it might be covered under service flash #26-758BR. In any event this job can be done by leaning the washer back against the wall to make room between the tub and front panel. You are going to need an assist, it's better with 2 people. Catriver...post back.
Posted on Aug 10, 2006
SOURCE: torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Posted on Mar 26, 2009
  • 530 Answers
SOURCE: I need to replace the molding door boot seal on my
you need to first unplug the unit. next you need to remove 4 screws that hold the dispenser lid on. next open the door remove 4 screws. remove the door and the out side panel. next located to the top left and right you will see a bracket with a 5/16 bolt remove them and take the bracket off. next lift the lid. you will have access to the door seal. you will see a spring at the top that is the band that holds the seal to the tub. the front of the seal just peels off. when putting the band and spring back on may be a little tricky. get one side up to the top gett a piece of duct tape and secure it. so that you can properly get the rest of the band on without fighting with it. get some vise grips and pull the spring over and attach to the part that is tapped. let me know if this helps or if you need more instructions.
Posted on Jun 21, 2009
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Basket rubs on door boot seal.
Be sure both lower and upper halves are correctly connect together
May 01, 2017 | Frigidaire Washing Machines
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Leaking door on a whirlpool Duet front load washer. What can I do?
odds are the "boot" front door seal, is bad.  tricky to replace and not really for the weekend warrior.  might want to  call the pros for this one..
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The boot seal/tub seal is torn and I want to replace this piece
door boot or baffle as it is sometimes called can be replaced. however it is not an easy job as there is a large spring that hold it on.
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
How to fix a tub seal on a front load Kenmore HE3 washing machine?
Replacing the door boot seal on these washers is not to bad at all. Go here for more info on the job: RepairClinic.com
May 05, 2009 | Kenmore 44072 Front Load Washer
Torn Door Boot
the way to replace it is you undo seal from front which might be a thin spring clamp behind the lip of the door seal it will be metal undo your lid look down the front of your washer to see the inside of the back of your door seal it will either be another bigger spring clamp or a screw clamp undo door seal will pullout replace backwards to how youve undone m8
Aug 13, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
378 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
