Question about Sanyo AVM-3259S TV
Sanyo ds325390 tv has good picture and audio but will only pick up cable channels above 48. The lower channels were deleted but I have added them back, however I cannot get the auto search to pick up these lower channels.
  • Anonymous Mar 17, 2014
    i have auto search and manual search but it seems my tv only pick up normal tv and not the dstv. But I had the same tv that worked on the cable and I had no problem. only swopped tv's
  • 244 Answers
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Posted on Nov 24, 2007
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
My sister has just bought me a Sanyo 26 inch TV (LCD-26XR9DA) but it won't pick up SBS and ABC jumps all over the place. I have an outdoor antennae and had no problems picking up the channels on my old...
Go to the TV setup menu and autodetect all channels. This should fix it. This is assuming your Sister is not using a set-top box.
In that case, you neet to leave the set on either channel 3 or 4, or use the video/audio input jacks and leave the set on VIDEO IN. The best picture with a non-HDMI set-top box will always be with the AV OUT from the box going to AV IN on the set [the white/red (audio left/right) and yellow(video) connections].
If she is using a set-top box with an HDMI output, connect an HDMI cable to the set and select HDMI IN for the absolute best picture.
Jan 29, 2011 | Sanyo Televison & Video
The channels won't work.
you can use another TV to test the cable.
Apr 30, 2010 | Samsung LN-R409D 40 in. LCD Television
Static on all cable channels
The tuner is questionable The problem lies inside the isolation box. Ask a repairman to open this isolation box and resolder the small board. There are two small resistors that need resoldered. This also has the rf connector on it. And you may have him resolder the tuner if this does not fix it. Have him inspect any and all grounds on the main board as well. Good Luck
May 31, 2009 | Toshiba CF32F50 TV
No picture or sound on channels below 48 above good
take your tv to a repair, he will open it and remove it from a card.
if you dont have a equivalent buy a universal tuner.
a tuner has only 5 or 6 pins,
he will manage to change
Mar 29, 2009 | Sanyo DS13204 TV
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
Press menu key
highlight channel scan memory
press vol+ to highlight number entry area
enter channel you want to enter eg. C16
or if above 100 press and hold the 1 key until C1--pops up
change deleted to added by pressing vol+
Nov 15, 2007 | Sanyo DS27910 27" TV
TV problem
Are you using cable to get the picture? If you are, make sure the TV set is in the cable mode,If it is then you most likely have a bad tuner in your set. Good Luck
Mar 21, 2007 | Sanyo AVM-1306 TV
Sanyo AVM-3259S TV Logo
165 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
