Question about Pool & Spa
Can't remove impeller to get pebbles out
I have the filter apart & can see pebbles, but don't seem to be able to take the impeller off, any ideas?
    President:
  • 1,378 Answers
What brand of pump? Most impellers are threaded on the shaft and you need to find a flat or slot somewhere along the shaft to hold it still while you spin off the impeller.
Posted on Jul 31, 2009
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
Dishwasher will not drain. Can hear it making a sound but water will not empty. Tried some liquid plumer but that does not seem to be working. When we try to drain there is a funny sound.
Hi
This draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My 665 won't drain. Any idea what the issue is?
Hi
Daniel
Aug 09, 2011 | Dishwashers
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Pump not taking prime. I have a lot of pine leaves or nettles some of which may have got past the strainer. after it took prime it did not seem to have good flow,.
This is indictive of a clogged impeller or blown shaft seal or possibly both.
To clean out the impeller, simply removing the 8 securing bolt that hold the wet end against the seal plate and motor housing. Then remove the diffuser assembley. You should now have access to the impeller. Remove any debris from inside the impeller and impeller cage.
Reassemble , fill with water, and try to reprime.
If prime still fails, take apart again and remove impeller to replace the shaft seal.
Note:
1. Make sure the filter connected to this pump is clean and not causing the problem before following these instructions.
2. Here is the link to the exploded parts diagram for easy reference to part names. It is also good to look at previous to dissassembley so that you have a good understanding of what is where.
Nov 11, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
Low pressure of 5 on our pool pump. Replaced sand, replaced filter O ring, no air leaks (no bubbles, no air in pump), and no clog in the filter line (bought a device to clear out any potential clogs, and...
Sounds like your impeller is clogged, you might be able to remove the pump basket and feel inside the impeller to see it it's impacted with debris. You may have to pull apart the pump to clean it thoroughly.
Jul 10, 2010 | Pool & Spa
Weak suction on rainbow se vacuum
Check for clogs in the nozzle air passages (remove bottom plate)
Check for clogs in the wand
Check for clogs in the hose (trow in a pebble or a penny and see if it comes out the other end)
Make sure separator is clean.
Remove exhaust cap (sometimes there is a sponge in the cap that gets disty and does not let the air pass through).Have in mind that it will not pick up well if the suction and the belt is good but brush roll bristles are worn and too short.
Good Luck,
Rocky
Dec 21, 2008 | Rainbow 75th Anniversary Canister Vacuum
Pool & Spa Logo
179 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
