Question about Acer Aspire 5100 3010 Notebook
Super slow. Opening files takes forever. There appears to be a D: drive labeled "DATA" but it is empty.
  • 53 Answers
Probably a virus... i suggest backing up all your important data and reformat.
Posted on Jul 30, 2009
My Computer Crashed I had the system drive replaced I need to reinstall the program
I'm not certain what you mean when you say that you did a recovery, but if your files are missing after the recovery, then this is not a good thing. In fact, I'd venture to say that at least some of your files are lost and gone forever.
The problem is that a recovery that involves something like reinstalling the operating system from scratch will almost always erase and overwrite whatever was on the hard disk. That means that your installed programs and your data may be overwritten by the newly installed operating system.
The good news is that it's possible that some of the data was not overwritten. However, continuing to use that hard drive decreases the amount of data that can be recovered with every moment that it's used.
Recovery steps In your shoes, these are the steps that I'd consider performing to recover lost files:
  • Start with search. It's possible that your files have not been erased or deleted at all. Perhaps your recovery was an install of Windows that preserved all of the files on the disk, but set up a new, empty "My Documents" folder. You might expect your files to be in this folder, but as it's a new, empty one, they're not. Use the windows Search function to search the entire hard disk for one or more files whose filename you know. If found, examine the containing folder and you may find more of your documents. Copy them to a safe location.
  • Run CHKDSK. Specifically, "CHKDSK /R" in a Command Prompt window (possibly run with administrative privileges in Windows Vista or Windows 7). If the file system has been corrupted by the crash, it's possible that CHKDSK may uncover lost files. If it reports that it has fixed something, repeat the previous step of searching for your files.
  • Run SpinRite. If CHKDSK reports unrecoverable read or CRC errors, then you may want to consider running a disk surface recovery tool, such as SpinRite. It's not free, but depending on the data that you might have lost, the cost could be very reasonable in comparison. After SpinRite completes (which can take hours), search for your files again. Note: SpinRite can be excruciatingly slow over a USB connection. If you elect to run SpinRite, you'll want a direct connection internal to your PC or perhaps an eSata connection if the computer and drive support it.
  • Run Recuva. Recuva is a free file recovery utility that scans the currently unused free space on your hard disk for files and file fragments that used to be stored there. Any files which were deleted by the recovery process, but not overwritten by subsequent use of the hard drive should, in theory, be recoverable by Recuva.
If your files haven't been recovered at this point, then chances are that they are gone forever.
One last straw to grasp at If you have a large budget (I believe we're talking hundreds, if not thousands, of dollars) and the data that you've lost is that important to you, then it might be worth contacting a data recovery service. Make sure that they do more than what I've just described (many basically do pretty much the equivalent of the list above).
Specifically, ask if they attempt to recover data that has been overwritten. This requires special tools and techniques not available to the average user and would be the reason for contacting them and using their services.
If all that they do is recover deleted files, then you're quite capable of doing that yourself as outlined above.
Above all, learn the lesson
Apr 20, 2015 | Computers & Internet
My Seagate Portable HD is not opening on my pc
To attempt recovery put it an an open external enclosure and have another one hooked up to recover the data to. Gently tap the hard drive with an open hand and see if you can get it to spin up one last time. Of course it can be sent to a data recovey company if you really have to get the data off. Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
There are no user serviceable parts inside the drive. Opening it will just negate any chance of recovery. You're not going to fix it by disassembling the drive. The click's indicate the drive it damaged; there is a good chance (98%) that you have lost all of your data. Note: By removing the cover from this drive the any remaining warranty will be void and all data will be considered lost. Now if you still want to take it apart just to look inside, there will be one or two screws that are under the manufacturer's label that will have to be removed. Pressing firmly, run you finger across the top of the drive until you can feel the depression where the screw head is. Using you screw driver puncture the label and remove the screw. Then you can pry the top cover off. Hope this helps. b>
Dec 21, 2012 | Seagate FreeAgent® GoFlex? Black 1TB...
Its 500 gb usb external hd. all of sudden its empty. there is not even a wd unlocker. its just totally blank. I kept it in my desk all the time so there wasnt any damage done. I really worried as had my...
Don't panic, you can recover files from external hard drive with asoftech data recovery program. get it from
http://www.asoftech.com/adr/
I have used Asoftech data recovery for hard drive data recovery for about 20 years, and they have never failed me...including the one time a disgruntled employee deleted everything and then formatted the hard drive. OnTrack was able to recover 95%+ of the wiped data within 24 hours of getting the drive.
Aug 19, 2011 | Western Digital WD Passport 250GB Portable...
Accidently emptied a trash bin that contained a very import ant file. How to restore this file?
1. If you simply put files in the Trash you can restore them by opening the Trash (left-click on the Trash icon) and drag the files from the Trash to your Desktop or other desired location.
2. "Time machine" is a built-in backup tool that works with your Mac and an external drive, As the problem you described, I read it. The files deleted in Trash bin could be a different problem which Time machine can't solve. you can read this article and learn more. I hope it will help.
3. If you don't have a Time Machine backup yet, then your best option would probably be uFlysoft Data Recovery for mac software
Mac File Recovery How to Recover Lost Files from Emptied Mac Trash
Mar 09, 2011 | Apple Computers & Internet
HOW TO RECOVER THE DELETED FILE IN THE HARD DISK DRIVE
That's easy, much data recovery software can solve your problem.I recommend you have a try of Wondershare Data Recovery,This program is equipped with four critical modules:"delete recovery", "format recovery", "partition recovery" and "raw recovery". It can help with your case.
Jan 11, 2011 | Sony Handycam DCR-TRV33 Mini DV Digital...
I lost some of my files from my pen drive. those files are infected by viruses, so i repaired them using anti virus. In dos prompt the folders are showing but while opening the pen drive the folders are...
your all pendrive folders hidden by viruses, so search your pendrive data
file name *.*
and
under advance option tick mark hidden and system files.
show all file.
Apr 23, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Recovery?
Since you are runing under Mac OS X, NO 1 choice is rely on Time Machine to recover from backup. If you do not set Time Machine, then you probably need a Mac data recovery software. But the first thing you need to take care is do not put more items to the Macintosh HD where those trashed stuff originally located. Learn more from this article recover emptied Trash Mac for more helpful information. Best regards.
Sep 16, 2009 | Computers & Internet
My computer is very slow
Download super anti spyware and run a scan
Apr 30, 2009 | D-Link DES 1005 Ethernet Switch
Motorola phone (i335) takes forever to recieve texts
It's the phone and the Iden network. The phone is the most basic of basic phones which is super slow and the IDEN network is only 800mhz it's super slow...
Apr 06, 2009 | Motorola Mobility I335 Cellular Phone
Acer Aspire 5100 3010 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
