Question about Kenmore 73952 Gas Dryer
My Kenmore 60 series gas dryer will not heat up. I checked the lint trap and it is clean. How do I open the front panel to check the pilot light?
What if the 60 series unit is pilotless?
Posted on Jan 11, 2010
    Problem Solver:
  • 6 Answers
Some dryers have a small inspection hole covered by a small platic cap.
Remove cap and look inside unit for pilot. Newer dryers have an igniter that glows when the dryer is turned on. It ignites the gas then goes out.
Posted on Jul 30, 2009
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
I have a Kenmore 80 series heavy duty dryer that is not giving out much heat.What should I be looking for to solve the problem?
Is it gas or electrric? Either one i would check the dryer vent hoses. Check the lint trap as well. The lint trp is the exit for the hot air to circulate. Sometimes if clogged with lint these dryers could go either way they could over heat and cause a fire or cause the element or thermostat to fail. The electric dryers have a thermostat and a heating element. Those tend to go bad. Back panel should be taken off and unplug unit check.
Apr 03, 2011 | Kenmore Dryers
The drum will turn, but no heat
Well if it's a gas dryer and if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Kenmore Dryers
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Kenmore 70 series that wont heat up can i just
well did check if burner is coming on is filiter clean is duck clogged. there should be sensor near the pilot light it should be close or even within the pilot light.
Jun 24, 2009 | Dryers
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore electric 80 series dryer not heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you feel confident here are the main things to do on checking for no heat Electric Heating Dryer:
1 Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most dryer models).
If you have 220v there the heater element is out.
2 If you don't have 220v on the terminals of the heater the problem is in the controls.
The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating thermostat(s), are all suspect and have to be eliminated 1 by 1.
Hope this helps.
With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan circulator on the motor, or if yours has little holes in the inside cabinet where the air is taken to be heated and recirculated, these can get clogged with lint also and cause a problem are the 4 main causes of low air flow..
Hope this helps and please rate me accordingly Thank you and good luck.
Sep 17, 2008 | Dryers
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
Kenmore 70 Series
Unless the dryer is extremely old, you do not have a standing pilot. It uses and ignitor or glow coil which could be your problem. It could also be defective gas valve coils or an open thermal fuse. Since it is a gas unit, I recommend you call a technician.
May 09, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
662 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
