Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My Liftmaster 1/2 HP garage door opener is not working at all. There is power at the outlet. I have 3 openers and only one is having a proble.
    President:
  • 3,197 Answers
You need to find out where you are losing the power. I would pull the logic board and look for burnt or missing traces on the printed circuit board and also look closely around the small transformer on the board for loose connections.
Posted on Jul 30, 2009
Liftmaster Model 1355 suddenly only works from remotes (3) sporadically. Changed light from led to incad. but did not help.
try leaving bulbs out a bad socket can cause range issues. also a bad ground on the wall/ceiling outlet can also cause problems.
Oct 05, 2016 | liftmaster chamberlain 1/2 hp chain drive...
Put up the opener but when we plugged it in we have nothing?
[PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
www.liftmaster.com/.../en.../tucmanuals/114A3044.pdf Chamberlain GroupThe Chamberlain Group, Inc. 845 Larch Avenue. Elmhurst ... Please read this manualand the enclosed safety materials carefully! ? Fasten the manual near the ...
Sep 03, 2015 | Craftsman 3/4 Hp Garage Door Opener System...
Craftsman1-2 hp garage door opener has no power .outlet works.
There is no fuse or circuit breaker in the opener. You should pull the logic board and check for loose or missing traces on the printed circuit especially around the small transformer.
Jun 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 HP Garage Door opener won't open or close. Has been working fine until I pulled out this morning. The door will move freely if I disengage from opener. Went up ladder to see chain not...
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
Feb 14, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a liftmaster garage door opener 1/3 hp. One side has a green light the other has a yellowish orange lignt on and it has stopped working. What is wrond with it?
Check for power at the outlet. Plug in a small radio or lamp. If you have power there I would remove the logic board and check for burnt or missing traces on the printed circuit board especially around the small transformer.
Sep 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENER WORKS INTERMITTENLY
Check to make sure your door sensors are properly aligned. They each have a small light and both lights will be on if they are aligned.
Jun 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi I have 1/3 hp liftmaster garage door opener that will not open from the remotes but will open with button on wall. I think it is a reciever problem?? any suggestions?/
reset your remotes and your main transmitter after removing and replacing the remote batteries (these use rolling codes that change each time you operate the door) the procedure for doing this is listed on the liftmaster website
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Oct 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
300 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
