Question about Oasis Hunter 54' Ceiling Fan
Wiring inside light assembly on fan
I replaced a damaged socket on the light assembly of a Hunter fan.Instead of just snapping apart the wire harness I took off the caps of the wiring inside the light kit assembly and now I don't know how those wires connect.
  • 75 Answers
Re: wiring inside light assembly on fan
If you have 1 light, you only need to put the hot wire, the one without ridges if it is extension type cord, to the center of the bottom of the fixture, and the other to the outside, or the neutral.
If you have more than 1, all you need to do is have one neutral, and one hot to each of the bulbs. It is best if the hot goes to the little one in the bottom, so it can not be accidently touched. So if you have 3 lights, you need 3 wires from the lights to the hot wire, and 3 wires from the lights to the other. If it is four, same thing, just add one.
Posted on Dec 22, 2008
0 characters
3 Points
How do I wire a light assembly,,,,my ex girlfriend toke it apart when she left...I have everything.need color codes.
See the link below and then enter the model number of your fan in the box. You should be able to retrieve the information you need from there:
Jul 17, 2015 | Hunter Fans
Hunter "French quarter " ceiling fan stops without being required to. Lights operate on or off without being required to.
loose wire connection White wire is neutral black wire fan blue wire lights. Since the light and fan are both affected that indicates the white wire is loose at the power panel or at the top area of the fan assembly.
Jun 15, 2015 | Hunter 52" Ceiling Fan With Light And...
Hunter Fan. Lights blinking on and off. I have read that it is the light governor and I should remove it and wire direct. I need more detail. Where is the light governor and how do I wire it...
the watt governor is inside of light assembly. it is a square black box. take this out and hook it direct, white wire to white wire, black wire to red wire. and this should solve the blinking lights. good-day!
Aug 10, 2011 | Hunter 22460 52'' The Astoria Brushed...
8 year old model has metal lamp shades one of which has come loose from its anchor. I need to get behind the socket to replace the nut which holds it in place. How can this be done?
You need to remove the entire light kit first by removing the 3 screws around the housing, one completely and just loosen 2 of them, turn slightly counter clockwise and pull down to release, depress wire harness clamp and pull apart, now you can work on the fixture.
May 17, 2011 | Hunter 52" Ceiling Fan With Light And...
We have a 2 year old Hunter Fan Model # 23285 The fan works fine. Last week the lights began flickering. We changed bulbs, checked for loose wires, etc. The lights go on dim and continue to flicker. ...
if problems with lights flickering. remove governor inside for the lights, and wire lights direct. this should cure problem. ( black box or governor ). part # 98480-02-- have a good day !!
Jan 06, 2011 | Hunter Ceiling Fans Individual...
My 52" Hunter Ceiling Fan with remote has been a gem. Last week when one of the light bulbs burnt out, I replaced the bulb, and then neither of the lights (it's a 2 light bulb fan) would come on. The fan...
The two bulbs are just having a separate live cable in parallel with the one of the motor.
So since you have mentioned that you had a burned bulb this sometimes causes a short inside the receptacle of the bulb. So you just need to disassemble the receptacle of the burned bulb and check both the wires live and neutral they are loose or disconnect or even melt and disconnect.
Is a simple operation since you need to check only two wires however it not so easy to remove the bulbs and reconnect the wires.
Oct 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Pretty annoying if you ask me.
Jan 25, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Hunter fan electrical problem
I have found in the past that when the splice caps were twisted onto the wires that they slip to the insulated part of the wire and looks as though it is connected actually is not. If you can get to the fan wires at the J-Box or ceiling fixture take the connection to the ceiling wires off and test the wires to the fan with an ohm meter to see if you have resistence reading. If you do not have a ohm meter take an extension cord and cut the female portion off and splice the wires to the fan wires. Make sure the cord will not hit the blades and plug the other end into a receptecale. If fan does not run then it is the motor wiring. Assuming you do not have a light kit since it was not mentioned. If you do and the lights come on then the fan wire was probably never hooked to that point.
Apr 28, 2008 | Hunter Installer's Choice 21222 Ceiling...
Oasis Hunter 54' Ceiling Fan Logo
237 people viewed this question
Top Oasis Fans Experts
Custom Exchange
Custom Exchange
Fan Fair Of Boca
Fan Fair Of Boca
Paul Taylor
Paul Taylor
Are you an Oasis Fan Expert? Answer questions, earn points and help others
