Question about GE (PSS26MSRSS) Side by Side Refrigerator
Compressor runs but circulating fan does not.
I have a G.E. TBX21CL. it's about 12 years old. it has been unplugged for at least a year. when i plug it in the compressor comes on but, the fan that blows air into the fresh food compartment does not. any help with this issue is appreciated.
thanks, Adam S.
  • 560 Answers
The fan motor is probably burned out. Pull the back panel off that houses the fan assembly (carefully as not to damage the evaporator) and replace it. This only applies if the compressor is running and the freezer is woking normally and there isn't excessive ice buildup on the evaporator binding the fan blades. If that were the case, you'd have a defrost cycle problem to correct. Anyways, the fan should run when the compressor is running. The only time it stops is when the unit enters it's timed defrost cycle which occurs about every 6 - 8 hours and lasts 20-40 minutes.
Posted on Jul 31, 2009
  • GE Master
  • 4,655 Answers
Sometimes when a refrigerator is closed up for a while the moisture collects on the fan motor. I recommend that you not run the refrigerator like this until you can remove the rear panel and try to get the fan spinning again . Try turning it and allow the rust to loosen up. This will get the fan going providing the fan has not burned out due to not spinning. Sometimes other things can cause this, but for now try this and if it works please rate me. Let me know if I can help you get your refrigerator going, that's what I am here for. Thanks, Sea Breeze
Posted on Jul 30, 2009
Frigidaire ffhi7f7hw stopped working, the controls are not respomding, the display reads "OF" seal is okay freezer is level, and the compressor wont kick in, this unit is only six and a half years old
Start by unplugging and cleaning it gets dusty of course then they cant circulate air, also if your freezer has too much stuff the air cant circulate an they sometimes over heat, did you notice it running all the time before it quit, was the temp good need more details after you first clean the bottom andunder neath, un plug first hope this helps
Apr 04, 2016 | Frigidaire Freezers
GE GSS25JF side-by-side: freezer not working.
I would change the 12 year old with a new model. The new models are more economic and the thechnic uses for sure less energy and the space is more, then the pump and engine the isolation less to.
Feb 04, 2014 | GE Refrigerators
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Dehumidifier runs but doesn't produce water
Your dehumidifier has a circulating fan that draws the room air over the coils. If there's no air movement out the front or back of the unit, the fan motor may be burned out or stuck, or the fan blade may be broken. If so, you need to replace the fan motor or the fan blade.
Sep 04, 2009 | Kenmore 5230 Dehumidifier
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Dec 31, 2007 | Refrigerators
Refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Jun 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
320 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
