Question about Philips LX9000R System
Wrong region??? Please help
My lx9000r has suddenly decided to start saying 'The region coding of this disc does not match that of the player' when in the past the same discs had played without a problem. Can you please help me rectify this, thanks.
  • 2 more comments
  • Dibx Dec 28, 2007
    I am having the same issue, it was working fine and now we have some new dvd's it say it has the wrong region code
  • HilCoop Jan 13, 2008
    "the region coding of this disc does not match that of the player" Any suggestion on how to change this to be able to play discs again?
  • Anonymous Mar 22, 2008
    Yep I have exactly the same problem. The dreaded "The region coding of this disc does not match that of the player" displays with many DVD's although not all of them. We have changed to other region codes to try without success then reset it back to "other". All the dvd's we have tried are either encoded for region 4 or all regions. Thankfully I have an 'extended warranty' so the retailer can sort it out. Maybe Philips thinks that Region 4 is too insignificant to do anything about it?
  • fmcala May 23, 2009
    Did anyone find a way to fix it?  I did once with a region unlock code but I lost it and the unit stopped working again....
    Mary
No..I bought it form Clive Peters in Brisbane Australia, I called up Phillips who are no hlep at all and mentioned about the setting where for over seas he said it should still play disc's then said it was out of warranty and that was that. I will no longer purchase Phillips products and have informed my Boss who deals with them and we are no longer going to stock their items due to their lack of support and rude customer service if you can call it that. You would expect a $2000 product to perform better than this
Posted on Feb 19, 2008
  • 8,596 Answers
The player you bought was marketed for another country - did you purchase it from an online vendor?
When i put a dvd in my hitachi htdk185uk it says unknown disc what does this mean
Either a DVD with the wrong region code has been loaded, and your player doesn't recognise it, or you have inserted a disc which is either rewritable (or an incompatible format for your player), a blank DVD or CD, or the disc has not been finalised in a DVD recorder. It depends on the disc(s) you have, whether they are region coded or those using a compatible playback format (finalised DVD-Rs are the best as far as burned copies go).
Examples of incompatible formats for your player may include;
DVD-ROMs
DVD-RAMs (which are the wrong version/speed for your unit)
Mini-DVDs/CDs
CD-RWs
DVDs with a different region code to your player or rewritable discs
* When using shop-bought DVDs, including those purchased online, make sure their region code matches your player.
May 25, 2011 | Hitachi DV-P315U DVD Player
Philips lx9000r 25S ome theater system Has suddenly stopped playing DVDs from Region 2 (no disc error) It will play DVDs from region 0 and CDs. Do not know access code, so cannot follow manual to change...
The Access Code is 0000 as default unless it's been changed
I think you'll find if it's not playing Region 2 DVDs that it's the same old Philips fault in that the laser has gone / is going.
Apr 13, 2011 | Philips LX9000R System
''Wrong Disk'' error
KM,
You'll need to check the region code of your player.
Make sure you have no discs in the player, and unplug the unit.
Plug it in and turn it on.
Open, then close the tray (with no disc!)
Press the Setup button, then select Load Setup
Press the Enter
While it it loading, press Menu.
When the box appears with a number, confirm it says 1 (region code 1 = USA). If it doesn't, please change it to 1 using the Up / Down buttons.
Press Enter to accept the change.
Jul 07, 2009 | TruTech DV288B3 DVD Player
Dvd not working
Check to make sure the regions match. Try lens cleaner. If that doesn't help, then dvd player is faulty.
May 14, 2009 | Televison & Video
Unlock region code for Insignia IS-HTIB102732
Call this number for Insignia technical help. Service : 1-877-467-4289. Hope this helps you with your problem.
Apr 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
Wrong Regional Disc
DVDs have region codes to prevent black-market selling of them and whatnot. Where did you buy the DVD? Where did you buy your DVD player?
R
I don't think so. What if you moved to another country? What if you decided to take your player on your yacht and sit out in international waters watching DVDs?
R
Try deregioning the hardware. Get the make and model number and enter it with "de-region" or "DVD region hack" into google. You may find instructions for de-regioning the player. It usually consists of taking any discs out, restarting the machine and then entering a number code that allows you to set the region to "0". Most of the cheaper, Chinese-made DVD players have a work-around like this. Post the model and maybe I can find it for you.
Dec 14, 2008 | Audiovox MMDV2
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Nexxtech N600 D wrong regional code
I have nexxt tech dvd 161-1000, I have the same prblem " Wrong Disc", I cleaned the lense, still same...Pls advice
Oct 15, 2007 | NexxTech N600D DVD Player
Philips LX9000R System Logo
205 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
