Question about Yamaha HTR-5730 Receiver
My center speaker crackles - Yamaha HTR-5730 Receiver
  • 38 Answers
Try connecting one of your other speakers to the centre channel on the amp to see if it is the speaker or the Reciever. If the speaker does not crackle then chances are the centre speaker is probably blown and will require replacing.
Posted on Jul 30, 2009
2 Suggested Answers
  • 30 Answers
SOURCE: Sony HT 6500 receiver...center speaker jack
try to spray contact cleaner into the speaker port itself.. Powered off of course.. let it dry and try again.. this will clean any connectivity issues due to bad contacts.. as far as replacing jacks.. try the suspected "bad" speaker and wiring in another port.. if it works then the speaker and wiring is good and you have to check actual jack in which you were asking and back to auto amplifier circuit or transistors.
Posted on Dec 17, 2009
Crackling sound coming from bose sound bar
my bose cinamate soundbar has a crackle in the center speaker ??? Why is this???
Dec 10, 2012 | Bose CineMateR 1 SR System
I have a Marantz 2275 receiver hooked to some JBL speakers. I noticed one of the speakers crackling. I swithched the speaker wires around and now the other speaker crackles so I'm guessing it is
Doesn't sound like it's a speaker - more likely a fried chip or transistor causing harmonic distortion.
It's usually more cost effective to replace modern audio components than to fix them.
Nov 21, 2017 | Audio Players & Recorders
Sony HT 6500 receiver...center speaker jack crackles as soon as speaker wire is connected to it. Tried new wire, new speakers...same thing. Tried to reset to factory settings...ONly L and R front speakers...
Dec 16, 2009 | Sony Audio Players & Recorders
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Dell WL6000 center speaker crackling
slightly reduce the base-boost knob at the backside of sub.....or change current audio theme to soft rock in audio proporties
Jul 26, 2009 | Dell WL6000 Computer Speakers
Boston Acoustics VR960 Crackle
I just finished repairing one of my VR960 units with a similar problem. My problem was that the sub would crackle no matter what input level. After changing a few of the active components, I finally discovered it to be a capacitor which was faulty. Anyway, I replaced the three 100uf 25V capacitors on the main board and all was well.
Good Luck.
Jul 07, 2009 | Boston Acoustics VR950 Main / Stereo...
Bose 901 Series IV BLOWN?
Yes, if you hear any sort of crackling sound, that means it has blown. Given the cost of these units, I would suggest repair. I would also suggest contacting Bose, as many of their products have a lifetime warranty, so you might be in luck. Although, blowing your speakers because you made your speakers go louder than they were supposed to, is no covered in the warranty.
You can approach the repair in 2 ways..
1) Send in to Bose for repair - suggested
2) Take it to a service center, and see if they will be able to recone the speakers or replace. Most service centers are familiar with the 901 series, so you should be ok. If they have no idea what your talking about, stay away.
But yes, they are worth fixing.
- OPTiC
DJ & Pro Audio Repair
Jan 17, 2009 | Bose 901 VI Main / Stereo Speaker
Speakers are crackling
This could be caused by one of your speaher wires being shorted out to ground, OR one of the speaker terminals in the doors or rear coming into contact with metal. If you remove the unit and test it with the speakers hooked directly to the back of the unit and they do not crackle, then the unit is fine. If they still crackle - then you either have two diferent sets of bad speakers, Or more than likely the outputs of the kenwood have been damaged by an improper installation in the past.
Jan 17, 2009 | Car Audio & Video
My speakers have almost constant crackling noises
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Apr 12, 2007 | Sony DAV-BC150 System
Yamaha HTR-5730 Receiver Logo
343 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
