Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Robinair 34700z not filling source tank / slow recovery
Our machine wont fill the source tank, and wont perform a full recovery.
    President:
  • 180 Answers
Please check the following:1# For not filling ISV tank (internal storage vassel) Check tank fill solenois,it's may need to rebuild or replace.2# For not compleet recovery,Check & make sure your machine compressor haveing 13''HG suction.if not then you have to replace new compressor.3# Check 13'' vacuum sensor is working properly.
NOTE:PLEASE CHECK FILTER CAPAICITY,BECAUSE EVERY 68Kg/150Lbs OF REFRIGERANT RECOVERY YOU MUST CHANGE SPIN-ON FILTER.
Posted on Jul 30, 2009
WHERE IS THE FILL SOLENOID
If you have model : 34788 or 34788-I please see the attached picture to identify tank fill solenoid. 37b7cee0-d212-4295-9e21-ab8d41e52789.jpg
Jun 25, 2014 | Robinair Cool Tech 34700Z Recovery,...
How to replace tank fill solenoid on robinair 34788
No, you cant remove tank fill solenoid until close low (Blue) and high (Red) side valve on ISV tank (Internal storage vessel). see attached picture to identify Tank fill solenoid. 39b3bb9f-14fe-4040-a186-3a3a23d2848e.jpg
Jun 18, 2014 | Robinair Cool Tech 34700Z Recovery,...
Where tank fill solenoid for 34788 cooltech
Please see attach picture of manifold assy. to find "Tank fill solenoid" (S11) with blue marked.
Jun 05, 2014 | Robinair Cool Tech 34700Z Recovery,...
I have a cool-tech34788 it wont refill internal tank keeps saying source tank empty i have installed a new tank and made sure valve was open and the source tank would flow
Please check ''TANK FILL'' hose quick connector & ''LIQUID'' hose on ISV Tank & make sure both valves is opening properly.it sound like(one of those) close! If valves is Ok then check tank fill solenoid, it may need to rebuild or replace. If those are OK, replace ''TANK FILL'' Hose.
I hope this will help you to solve the problem, if so please vote for it. Gool luck!
Aug 24, 2010 | Robinair Cool Tech 34700Z Recovery,...
Machine will not read scale or does not weigh freon . will evacuate but will not charge says tank needs fill but will not fill either
Most robinair units require the filter to be changed every so many uses. If the filter is not been changed, the unit will not work.
Aug 14, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34788, Will not fill (IVS) tank from source tank .... tried three different tanks from three different distributors ... Indicates that source tank is empty .. All brand new tanks.
Aug 09, 2010 | Robinair Cool Tech 34700Z Recovery,...
ROBINAIR 34788 NO MANUAL REFILL
You may did not open the tank valve before you press fill key! please try as bellow:
Connect tank fill adapter to source tank & open tank valve then make the tank up side down,now press tank fill key. screen will change to checking source tank for 30/60 sec. then start filling.
If you try as above direction & still the problem exist,it may need to replace or rebuild tank fill solenoid.
Jul 14, 2010 | Robinair Cool Tech 34700Z Recovery,...
How do you transfer new refrigerant to tank
Connect fill hose ( Black hose with 2/1'' quick connector located at near the tank strip) to source tank (New R134a refrigeration tank) & make up side down. switch on the machine power switch. Press main menu key then keep pressing up or down arrow key till appear "Tank Refil" on the display screen. with "Tank refill" on screen press YES key. the message will change to ''Checking source tank" for few second then start filling refrigerant to ISV tank. press NO key to exit when you want to stop filling.
Hope this will help you, Good lucl & vote for my solution!
Jul 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
Wont clear filter
If the clearing the filter screen will not go off then it is sure that compressor is not good.please check the compressor with vacuum gauge & make sure is has 13" HG of suction.
Aug 12, 2009 | Robinair Cool Tech 34700Z Recovery,...
Source tank empty
You have to rebuild tank fill solenoid.Thank you.
Mar 26, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
1,243 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
