SOURCE: The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
SOURCE: Flickering screen (likea strobe light)
Problem with flickering is in the board that is mounted to the back of the lcd screen. Part is only available in China.
Board will either need replacing or repairing (if it is repairable? Not all are)
I repair lcd monitors on ebay and just repaired one of these boards.
ebay id: bammbammfran
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
