Question about Sony Ericsson Z530i Cellular Phone
It wont turn on, like is the turn on swithc the
It wont turn on, like is the turn on swithc the bottoms right, is it broke or just faulty?
    President:
  • 1,884 Answers
Its your phone. Read the User Guide that came with the phone. If you know where the switch is and the phone does not switch on then your switch may be faulty, have it repaired. Or the battery may be absolutely dead. recharge it. Or the phone itself may be dead. have it checked up.
Posted on Jul 30, 2009
1992 back right tire seized and wont turn
it appears that the brake is faulty and when in forward direction is putting itself on. It is free in reverse. check the brakes are in good condition and properly retained
Apr 04, 2014 | 2001 Cadillac DeVille
My tx500 has a e7 on display and wont start what can i do
Dear Sir:
has 2 options this error:
1) elevation motor: a) motor faulty b) grease and lube the gear c) adjust the potentiomenter d) gear and bars lube e) main motor board faulty. see my personal TIPS FOR HELp.
2) see the attached diagram for adjust the reed swithc, clean, and tight the ribbon cable from keypad , and tight the connector from display board vs lower board. b) the display boad can be faulty.
In short after you did the adjustment,RUN INMEDIATELY, the software calibration for diagnose and troubleshooting.
May 01, 2012 | Sportcraft Exercise & Fitness
Pro form consel displays PO and will not start
Dear Sir:
This is probably a 1)faulty speed sensor or 2)speed sensor is not plugged in properly. 3)faulty motor control board 4) adjust the reed swithc. The error codes will differ between makes and models but could be e1.
see the diagram for boths adjustment. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 18, 2012 | Exercise & Fitness
I changed the the starting solenoid in my 89 ford bronco, but it wont start. its not turning the starter over at all. What color is the ignition wire, and where dose it connect to? (is it the top or bottom...
try starting in neutral. It could be the neutral - park safety swithc.
Or, try jumping the solenoid at the starter. Make sure in park and brake applied.
Feb 25, 2011 | 1989 Ford Bronco
Philips 42PF5320 plasma - unplugged and plugged in. wont turn on
This is a common problem on these plasma TV's. The problemresides in the high voltage boards known as the X and Y Sustainboards.. You can purchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Sep 14, 2009 | Philips Televison & Video
Royal Orca 9512x was moved to another room and now it won't turn on. A square piece of plastic fell into the basket. But we can't tell where it came from. Not sure if that's related or not.
Make sure that switch on back right foot is setting down on paper bin. It makes the contact that turns all on. I also had to use swithc cleaner from Radio Shack to clean my main swithc on top control panel.
Jul 12, 2009 | Royal 15MX Shredder
C920 turns off wont turn back on.comes on when on charge but when charger is removed phone turns off
Friend the power swithc of the phone is shorted. use an electronic tester to solve it. replace the power switch if possible
Jul 10, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Faulty Sony Ericsson Blutooth
Well i also have a z530i and my screen broke . my bluetooth hasnt done that and i dont have a problem wiht my nokia 6233 or my n95. but i suggest you look on your infared settings and then turn it off IF it is on . then go back onto bluetooth or go on your shortcuts ( bottom left button ) and click bluetooth . if this doesnt work , just take it to a shop and ask for there suggestion. Hope i helped
Oct 17, 2007 | HP iPAQ H2215 Pocket PC
Sony Ericsson Z530i Cellular Phone Logo
93 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
