Health & Beauty Logo
Julie Seiter Posted on Dec 13, 2017
How to check blood pressure and not just heart rate
5 Related Answers
Anonymous
  • Posted on Mar 20, 2009
SOURCE: blood pressure machine does not give heart rate infor
I finally got through to the company customer service person and found the machine has ''gone defective.'' They will pick up this one and send a replacement.
David Shaub
  • 2994 Answers
  • Posted on Apr 23, 2009
SOURCE: Timex heart rate monitor does not keep correct BPM. I changed the battery, now the heart rate hovers in the 30' and 40's, never getting to the correct BPM
Make sure the back of the watch is spotless and your skin isn't too dry.
vpaaf
Howard
  • 115 Answers
  • Posted on May 01, 2009
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Anonymous
  • 10865 Answers
  • Posted on Mar 19, 2010
SOURCE: heart rate monitor not working
Remove the batteries and clean the battery contacts inside the device with a common pencil. Then insert new batteries that you know are fresh. That should fix it. If it still won't work for you go to Garmin.com and send it in for repair. Joe
Anonymous
  • Posted on May 14, 2010
SOURCE: How to clear memory on a ReliaMed wrist blood preassure machine
  • Make sure the unit is off
  • Hold down on the memory button until you see "CL" (clear)
  • Once you see CL appear on the screen release the memory button then tap memory once
  • You will hear a series of beeps
  • Memory is now cleared
  • Ad
    Blood Pressure Readings. Why are my readings so much higher than the ones I have at the hospital?
    Question edited for clarity, as I assume that you are talking about Blood Pressure and Heart Rate?
    You can intentionally lower your blood pressure, and even easier to lower your heart rate.
    You should always take best of three readings a couple of minutes apart. You should breathe deeply and relax. You blood pressure cuff should be level with the heart. If you are overweight, you should sit up straight as 'slumping' puts pressure on the heart.
    Resting heart rate should be 72, but 60 to 100 is fine
    https://www.henryford.com/blog/2019/09/resting-heart-rate-says-about-you
    Understanding Blood Pressure.
    https://www.heart.org/en/health-topics/high-blood-pressure/understanding-blood-pressure-readings
    Was in the ER last week cause blood pressure went down to 42. I got it back up but today it has loered to 67. How can I raise my blood pressure now here at home
    Not enough information to answer safely.
    A Blood Pressure of 67 makes no sense, as there are 2 numbers.
    For example 150/90
    The top number is the Systolic pressure, the pressure when your heart contracts.
    The bottom number is the Diastolic pressure, the pressure when your heart relaxes.
    Depending on many factors a bottom number of 67 may be very normal.
    For example if you are a small elderly woman 67 would not be unusual.
    Young athletes in excellent physical condition also have lower blood pressures.
    I don't know why you went to the ER.
    Nothing you have said so far indicates there was an emergency.
    Were you having serious symptoms, or were you merely anxious and checking your blood pressure (or your pulse) by yourself.
    I am wondering however if you mean pulse, i.e. heart rate, instead of "blood pressure".
    A heart rate of 67 again might be very normal and not need to be changed.
    When your pressure is132 youe heart rate is 75 and puls is 75 what tha mean
    I am thinking what they meant to say was that your blood pressure is 132 over 75 and your pulse is 75. Blood pressure has two readings, a high and a low one. If this is the case, your blood pressure is fine and your heart rate (the number of times your heart beats per minute) is also fine!
    4helpful
    4answers
    What causes low blood pressure?
    low blood pressure dangerous only if it causes
    noticeable signs and symptoms, such as:
    Dizziness or lightheadedness
    Fainting (called syncope )
    Dehydration and unusual thirst - Dehydration can sometimes
    cause blood pressure to drop. However, dehydration does not
    automatically signal low blood pressure. Fever, vomiting, severe
    diarrhea, overuse of diuretics and strenuous exercise can all lead
    to dehydration, a potentially serious condition in which your body
    loses more water than you take in. Even mild dehydration ( a loss
    of as little as 1 percent to 2 percent of body weight ), can cause
    weakness, dizziness and fatigue.
    Lack of concentration
    Blurred vision
    Nausea
    Cold, clammy, pale skin
    Rapid, shallow breathing
    Fatigue
    Depression
    Low blood pressure can occur with:
    Prolonged bed rest
    Pregnancy - During the first 24 weeks of pregnancy, it's
    common for blood pressure to drop.
    Decreases in blood volume - A decrease in blood volume can
    also cause blood pressure to drop. A significant loss of blood
    from major trauma, dehydration or severe internal bleeding
    reduces blood volume, leading to a severe drop in blood pressure.
    Certain medications - A number of drugs can cause low blood
    pressure, including diuretics and other drugs that treat
    hypertension; heart medications such as beta blockers; drugs for
    Parkinson's disease; tricyclic antidepressants; erectile dysfunction
    drugs, particularly in combination with nitroglycerine; narcotics
    and alcohol. Other prescription and over-the-counter drugs may
    cause low blood pressure when taken in combination with HBP
    medications.
    Heart problems - Among the heart conditions that can lead to
    low blood pressure are an abnormally low heart rate
    (bradycardia ), problems with heart valves , heart attack and heart
    failure . Your heart may not be able to circulate enough blood to
    meet your body's needs.
    Endocrine problems - Such problems include complications with
    hormone-producing glands in the body's endocrine systems;
    specifically, an under-active thyroid (hypothyroidism), parathyroid
    disease, adrenal insufficiency (Addison's disease), low blood
    sugar and, in some cases, diabetes.
    Severe infection (septic shock) - Septic shock can occur when
    bacteria leave the original site of an infection (most often in the
    lungs, abdomen or ******* tract) and enter the bloodstream. The
    bacteria then produce toxins that affect blood vessels, leading to
    a profound and life-threatening decline in blood pressure.
    Allergic reaction (anaphylaxis) - Anaphylactic shock is a
    sometimes-fatal allergic reaction that can occur in people who are
    highly sensitive to drugs such as penicillin, to certain foods such
    as peanuts, or to bee or wasp stings. This type of shock is
    characterized by breathing problems, hives, itching, a swollen
    throat and a sudden, dramatic fall in blood pressure.
    Neurally mediated hypotension - Unlike orthostatic
    hypotension, this disorder causes blood pressure to drop after
    standing for long periods, leading to symptoms such as dizziness,
    nausea and fainting. This condition primarily affects young people
    and occurs because of a miscommunication between the heart
    and the brain.
    Nutritional deficiencies - A lack of the essential vitamins B-12
    and folic acid can cause anemia, which in turn can lead to low
    blood pressure.
    Severely low blood pressure can have underlying causes that may:
    Be an indication of serious heart, endocrine or neurological
    disorders
    Deprive the brain and other vital organs of oxygen and
    nutrients, ultimately leading to shock, which can be life
    threatening
    1helpful
    What is a normal blood pressure for a 72 year old male
    talk with your doctor as blood pressure readings vary between patients, weights , age and health conditions
    always have your blood pressure done by the doctor as that will give a record of any variations that could be harmful
    at this point it seems slightly high but the bigger concern is the diabetes and what ever the heart condition is
    again consult with your doctor and get a proper diagnosis
    1helpful
    When blood pressure is 105 over 54. Heart rate 60. is pressure to low?
    Yes, little low. Normal is around 120/80mmHg. Rate is fine.. Normal is 70 at rest. Check placement of cuff and it is level with your heart
    2answers
    I NEED AN OWNERS MANUAL FOR BA-616W ...GOT IT 2 YRS AGO AND ONLY HAVE THE INSTRUCTION SHEET ..BUT I NEED TO KNOW HOW TO READ THE NUMBERS AND WHAT THEY MEAN. PLEASE HELP
    As a 30 year EMT, I think I can help you.
    There's 2 numbers that make up your blood pressure. The top number is called the Systolic pressure. The bottom number is call the Diastolic pressure. When a blood pressure is taken, it's measuring the pressure that the heart is producing when it pumps blood through the arteries. For example, what's considered a normal blood pressure in a healthy individual is in the range of 120/80. Of course age, life style and other health conditions, play a role in what yours may be. A person with High blood pressure or Hypertension would have a blood pressure of over 160 - Systolic and over 90+ Diastolic. 90 is actually the borderline for hypertension. That's why I indicated 90+.
    The other reading on your monitor is your heart rate or pulse rate. It's how many beats your heart completes in one minute. It also indicates an irregular heart beat by the showing a small LED window on the left of the screen adjacent to the Systolic pressure reading, It will say IHB. Any movement or shaking or talking during the measurement can result in pulse irregularities. So hold very still when taking your blood pressure. This irregularity by itself is not of much concern, unless it shows up frequently. In which case, you should seek medical advice.
    That covers just about all there is to know about what the readings mean. Armed with this, you should be able to effectively monitor your blood pressure and pulse rate and report them to your doctor.
    Hope I was able to help you understand how it works and what it's telling you. if so, please let me know, by rating my response to you. Thanks and have a healthy day.
    1helpful
    5answers
    Blood pressure Question
    Measuring your own blood pressure is an important way of monitoring your health. High blood pressure is a major health problem, which can be treated effectively once detected. Measuring your blood pressure between doctor visits on a regular basis in the comfort of your home, and keeping a record of the measurements, will help you to monitor any significant changes in your blood pressure. You should also keep an accurate record of your blood pressure, to help your doctor diagnose and possibly prevent any health problems in the future.
    Top Health & Beauty Experts
    Rob Hill
    Rob Hill
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
