Question about Husqvarna Garden
Husqvarna 345e starts, runs a short while and then dies out. If I open the fuel cap it runs a little longer.
    President:
  • 1,273 Answers
There should be a pinhole vent in the cap. Clean this and check/clean/replace the spark plug. If this doesn't get you running well, do the following: Check that you have an adequate fuel supply to the carb body. If 'no', clean your way back to the tank. If "yes", remove the air cleaner (clean it as you go), and spray gumout into the carb. Let it sit a minute, and spray it again, paying particular attention to the orifices. Working the trigger as you spray will give you better access to the interior of the carb. Lubricate the external linkages, and reassemble the air cleaner. This should be everything needed to get you cutting. If all else fails, you can remove and clean the carb, but try with it mounted first. Any adjustment screws that you manipulate should be returned to their initial position so as to not make the issue worse. If I have to move an adjustment screw, I always screw it in until it bottoms (counting the number of turns, and then back it out. I always make a diagram/picture of what I disassemble and put critical info on the drawing (I might have an arrow pointing at a screw with the note 3 and 1/4 turns, etc.). This cuts down on a lot of guessing later, and makes reassembly much easier.
I hope hat this was helpful. Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
Husqvarna 125l carb problems
Check the fuel lines. Ethanol in the gas swells the old type fuel lines.
Jul 17, 2014 | Garden
Why does my klr die after 15 to 20 minutes ? I HAVE A 2008 KLR WITH 15000 MILES ON IT . This year it started dieing after about 10 miles. First it misses a little then more the longer it runs before...
possible block in gas tank vent?? try cracking the cap a bit when the issue happens. if it keeps running you may need a new gas cap. go with the easy stuff first...always
Jun 27, 2017 | 2008 kawasaki KLR 650
Lawn mower starts dies
Try running it with a loose fuel cap. If it runs fine the fuel tank vent is plugged. Some mowers have a little hole in the fuel cap that gets plogged up.Use a pin to clean it out.
May 29, 2013 | Husqvarna 7021P 21-Inch 160cc Honda GCV160...
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
Chainsaw stops running
When it starts to die slacken off the fuel cap enough to allow air into the tank, if it picks up again it is an issue with the fuel tank breather, if the breather is blocked it will create a vacume in the tank and stop fuel flow to the carb.
Apr 24, 2012 | Husqvarna Garden
I have a 326L. The trimmer starts and sounds like normal. After about 5 minutes it starts spuddering and then dies as it losses power. Then I cannot start it again. I have a new fuel filter and I have...
Sounds like your fuel cap may not be venting properly. If no air can get into the fuel tank, then after a short while of running, no fuel will be able to be sucked out, thus starving the engine. You can find replacement fuel caps at PartsBuggy.com.
Aug 29, 2011 | Husqvarna 28cc Gas Line Trimmer
Starts and runs good for 5 maybe 10 min. then it dies and won't start and run right
Remove the fuel cap to see if the saw will run longer--if so, the fuel vent would appear to be plugged. If no help, then check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Hope some of this helps!
Jan 03, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a relatively new 16" Husqvarna chainsaw, and I have the hardest time getting it started....sometimes I can't even get it started. Once I get it going, it usually runs fine, but it is extremely...
We have a Husky 435 (two year warranty) that was new last year. It would start and run fine for several days, then nothing--took to warranty service where they replaced the ignition module the first time. Ran for several more days, then nothing again--this time they replaced the carburetor and it seems to working fine from then on. Suspect that Husqvarna has had problems with our ethanol-blended fuels. If you still have warranty coverage, then take advantage. Hope this helps!
Jul 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw (Husqvarna 345e) will not start due to start attempt without adding oil to fuel.
If this was started without oil in fuel, then the piston is likely scored, and the compression rings stuck in a smeared aluminum mess. You can remove the muffler and probably see the damage to the piston. It can probably be repaired though. Take it to a reputible shop, then read the owners manual and get some help to learn how to safely use and maintain your investment that you have in this saw.
Jul 04, 2008 | Husqvarna Husky 165
Garden Logo
99 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
