Question about Magellan Roadmate 760 GPS Receiver
Can not lock in satellite signal - Magellan Roadmate 760 GPS Receiver
  • rfeezor3 Sep 29, 2009
    roadmate 760 cannot get a satalite lock and keep it why?
    Problem Solver:
  • 5 Answers
Plug it in, turn it on and let it sit out in the open. Make sure the antenna is flipped up with as much exposure to the open sky as possible in your vehicle. If the unit is working at all, it will eventually find and lock onto the satellitescan not lock in satellite signal - 2.gif. The 760 I'm using now came from California and it took over 2 hours to lock on. When I start a trip now, I let it sit before starting to drive and it locks on in just a few minutes.
Posted on Nov 01, 2009
    Brigadier General:
  • 4,090 Answers
The possible causes of this are as follows
The batteries or battery is too low and eitjher need charging or replacing
The port or baud rate is not set correctly
it does not havce a clear view of the sky
The SIIRF chip is damaged or the unit has been dropped
The antenna is damaged or disconnected inside unit
Posted on Jul 30, 2009
Does the gps on life360 require both internet and satellite to work
It requires Internet to update maps, install corrections, or additional features. It requires the GPS signals transmitted by the satellites to know where it is and where to go.
If you do not want to update the device you need just the GPS signals. However those satellites may be moving about and theirs positions have to be reported to the device otherwise it will take it longer to lock in on the signals, and might even never find the satellites.
Jan 13, 2014 | GPS
Whenever I use location function using GPS, the phone just hangs. Any solution?
  • This may not fix the problem but here are some tips that will help. When it is "just hanging" it is trying to receive a satellite signal. These are helpful tips to receiving that signal.
  1. Make sure you are outside and in the open. This is a phone and while it has GPS functions you have to be in the most optimal position.
  2. GPS units that work well have an antenna made to receive satellite signals faster than the phone antenna.
  3. Make sure you are standing still and not driving or walking fast. You have to give the satellites time to lock in on your position.
  4. Bad weather or even an overcast can effect satellites transmissions.
  5. Satellites move around and sometimes they are temporary a bit out of range.
  6. If a signal is not found try again a bit later and see if the satellites signals are being received better.
Regards, Tony
May 23, 2011 | Apple iPhone 3G Black Smartphone
I don't have Satellite signal! I tried to acquiere satellite signal with my Garmin Nuvi 1350! The screen always says locating satellites but nothin happens! The satellite bars are not green!What can I do...
Try fully charging the unit and leaving it stationary for about 20-30 minutes if you still dont lock satellites try giving the unit a firmware updates using Garmins WebUpdater software here is a link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 350 GPS Receiver
I've had the tom tomxl 330s for over two years, it has never had a satellite signal, i've attempted several times to restert, the gps is updated, my configuration is in degrees, which seemed to activate 2...
its good you have 2 satellites but you need to see more for it to work.
the tt can take quite a long time to lock on.
make sure you have completely free view of sky and away from any buildings.
Give it a few minutes to lock on.
also make sure you have latest firmware updates from TT as they also do a regular position update of satellites.
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Tomtom One XL GPS Receiver
Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
Not getting a GPS signal. What do I need to do?
Usually, after you turn on the GPS device, it may take a minute or so to start up and lock into the satellite signals. While it is waiting to get a valid GPS signal, it is "listening" (scanning) for satellite signals to establish your current location.
If you are in the open outdoors, i.e. not inside a building or under extended covers, it should get the satellite signals within a minute or so.
If you still can't get a GPS signal, consider shutting it down ... using a "hard" shut-down (hold down the on/off button for 5 seconds or more ... to re-boot the system/software programs. Then, wait a while before starting it up again. Make sure your device is plugged in and/or the battery is NOT low when you're doing this.
Jan 02, 2011 | Tomtom GPS
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
291 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
