Question about TV Receivers & DVRs
JVC plasma display receiver - sporadic line problem!
Hi i wonder can anyone advise me. We have a JVC 42" plasma TV with a plasma display receiver (super digi pur BBE). We have only had it 2 years, and all of a sudden we started getting static vertical lines about an inch appart in the picture which go temporaraly when you bang / apply pressure to the top centre of the display reciever.... we have no idea how to get rid of this and am hoping someone can help?
Many thanks
Re: JVC plasma display receiver - sporadic line problem!
Ik heb dit probleem ook sinds gisteren, hoop dat iemand weet hoe dit opgelost kan worden.
Posted on Apr 30, 2010
0 characters
3 Points
I have jvc tv which has served me well for the past 11 years but off late it has been displaying some lines on the screen and losing colour when its on both tv and video mode,but when i touch the aerial...
Your TV have problem with cold-solder joints.Input terminals (inside TV ) need to be resolderd.After 11 years from internal heat of the TV solder becomes weak (dry out) and loses conntact from main board where components are soldered
Aug 22, 2011 | JVC TV Receivers & DVRs
Phillips Plasma 42PF3320
I have phillips 42" plasma tv it has 7 red light flashes at start up and locks out
Jun 15, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | TV Receivers & DVRs
Philips plasma
I had this problem. If you are saying it happened on your plasma screen rather than the receiver box, then the problem can be that the power source inside the plasma needs to be replaced.But Philips will charge a fortune for just looking at the TV. So you might as well take it to your local repair shop.
Jan 15, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Advise on how to wire tv home entertainmet dvd hdi cable together
hdmi is the least amount of cables you'd need to run, 1 cable for audio & video for each device, assuming they have hdmi outputs on them and you have enough inputs on your tv.
Dec 22, 2007 | TV Receivers & DVRs
Phillips plasma 42 in tv thin
malfunction of the vertical output integrated circuit
Dec 22, 2007 | Philips E-Box FTR9965 DTV Receiver
Looking for where to find this part
You need to fix power supply module (replace electrolitic capacitor on PCB) in your plasma. It's very frequently failure for this device.
Nov 20, 2007 | Philips E-Box FTR9965 DTV Receiver
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
TV Receivers & DVRs Logo
908 people viewed this question
Top TV Receivers & DVRs Experts
Jaime Hernandez
Are you a TV Receiver and DVR Expert? Answer questions, earn points and help others
