SOURCE: Blue-ray disc causing Sony blue-ray player to shutdown
No memory issue check on Sony's Website for Firmware update for your specific model and doenload and update your player
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
SOURCE: will not play Blue Ray DVD
I had the same problem. Try this. Contact Sharp and have them email you the firmware update. You will need to download it from the email and transfer it to the player via a flash drive. See if that works. I am about to return my Sharp Blu Ray player to Costco and go back to DVD. There seem to be a lot of problems with the technology. Even when movies start to play, they have freezes and it is sometimes hard to get the menu to show up
SOURCE: How do I reset Netflix on my insignia NS-WBRDVD
Go to the settings menu of the Insignia, click on "Reset" settings and then select "Deactivate Netflix".
Next, restart the player and access the Netflix once again to reactivate it.
Testimonial: "Thank you very much that helped... I was able to do what I wanted to do for the last two months and couldn't . Thank you again..."
SOURCE: Need activation code for Netflix. I own a Samsung
after you have Samsungs logo too activate for TV, it will have a code already for you on t.v. screen...now on your laptop,desktop, etc. copy and paste the link below to browser, and you will/or should be at the code app box. fill in TV number, enter,....and you will see TV asking for you too accept or decline "pairing" it should b cool 4 cats!(Bonnie Scotland for ever!)https://accounts.google.com/o/oauth2/device/usercode
