SOURCE: Using headphones with Logitech X-230 speakers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
SOURCE: Audio Out Fixed/Variable
Is your subwoofer amplified or passive?
You clearly understand that you need to use a variable line out to control the subwoofer volume via the TV. As the setup seems reasonable, I'm wondering if the subwoofer is getting a signal, but that it is at line-level and not internally amplified by the subwoofer speaker. Generally, if the subwoofer must be plugged into an AC socket in the wall, it has an internal amplifier and can be fed line-level audio. If it is "passive", it has no amplifier, and it must receive an amplified signal (over speaker wire) from an amplifier (or integrated receiver). TV's don't generally have connections to send out an amplified signal.
If the subwoofer is indeed amplified, then this is obviously not the problem, but it's the first thing to verify given the information provided.
SOURCE: Audio volume controller not properly working
I am not sure about the solution, but I had a similar problem. My technician opened up the controller and cleaned it physically, this solved my problem. I hope it solves urs too.
Regards.
SOURCE: Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
