Question about Acer Aspire One A150-1006 Notebook
Lost ip address so can't connect to wireless - Acer Aspire One A150-1006 Notebook
  • 596 Answers
If you are able to connect to the router via Ethernet cable, connect, go to the gateway ip address and you can retrive the IP address info from the routers configuration page.
Good Luck.
C2Solutions
Posted on Jul 30, 2009
3 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: Acquiring Network Address
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
Posted on Jan 26, 2009
leecom72
  • 4806 Answers
SOURCE: can not get wireless connection on asus notebook
Try resetting the network adapter.
On the bottom right hand side of the desktop you will see the wireless icon, right click on that ans click on troubleshoot problems. This will reset the adapter and assign an IP address for your your PC.
When its done try to connect to the internet.
If this advice does not help please post back.
Good luck.
Posted on Jan 11, 2010
Canon IR 2520 lost IP address
This is regular feature. Nothing defective here.
IP address is to communicate with the router on wire or wireless.
Dynamic IP address will assigned to your printer again when re-connected and will be lost when disconnected.
Static IP address assigned will be reserved at the router for the device even when the device is disconnected.
Apr 18, 2016 | Canon Office Equipment & Supplies
Lost box and directions on how to set up this printer. Need to find TCIP IP address of this printer to connect wirelessly with laptop
it does not have ethernet adapter according to the specs no no ip address or interface ?.
Do you have the optional bluetooth adapter with the printer. ?
You may be able to connect via bluetooth
http://classroom.synonym.com/make-kodak-printer-wireless-bluetooth-17749.html
http://support.en.kodak.com/app/answers/detail/a_id/1157/selected/true
http://www.amazon.com/Kodak-Wireless-Adapter-Printer-Dock/product-reviews/B0006NMSK6
Oct 13, 2015 | Kodak EASYSHARE 5100 All-In-One Printer
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
Was working on my laptop upstairs and it told me I lost my internet connection. The IP address was192.168.2.1. Now all of a sudden can't assess my network from any wireless device. When I type in...
1. First thing you should do is RESET (both) the router and modem.
2. Check if the wireless and wired connections are ok.
3. Contact your ISP, let them check your status.
Jul 03, 2011 | Dynex DXWEGRTR Router
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
I have a hp pavilion dv7-2277cl laptop (64 bit) and a hp laserjet 2605dn. suddenly the communication between the two has gone missing. This is a wireless network and worked until last week. I have down...
The one that is missing in the network is the printer.So try to reconfigure the IP of the printer again using the wireless wizard in the printer manager. Or go to Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English)
Also ; Very seldom does the printer itself cause problems. To determine if you have printer trouble, do the following:
  • If you're using a wireless connection, see if the wireless indicator lamp is illuminated? Can you turn on the wireless radio from the control panel of the printer?
  • Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
    • Does the Wireless Network Test report indicate trouble?
    • Does the report indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
    • Compare the printer's IP address [X]
      IP address
      An IP address is a series of numbers by which computers, printers and other devices on a network are known. An IP address is usually issued by the local wireless router (network) from its DHCP service. A device is given an IP address that is similar to the wireless router's IP address. For example, if the wireless router's IP address is 192.168.1.1, a printer may be given an IP address of 192.168.1.5. to the gateway IP address [X]
      Gateway IP address
      This is the IP address of your wireless router. . They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
    • On some printers, the Network Configuration page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
    • Are there several wireless networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
  • Are there any error messages on the printer or unexpected blinking lights (consult your manual to determine what to expect)?
  • Reset your printer (usually by removing the power cord from the back of the printer, waiting 30 seconds and then reconnecting the cord. Consult your manual for specifics).
  • Restart your wireless router [X]
    Wireless router
    A wireless router is networking hardware that allows both wired and wireless devices to connect to a network. When connected to a wireless router, devices such as computers, printers, and other Wi-Fi enabled electronics can share one Internet connection AND connect to each other. Connections can be made to the wireless router through a wireless connection or a wired connection using an Ethernet cable. by unplugging the power cord, waiting 60 seconds, then reconnecting the cord to the wireless router.
Dec 16, 2010 | HP Color LaserJet 3500 Printer
Intermittent wireless Internet access
The problem started after you added the additional devices. Now you probably have all of your devices using DHCP which means the router provides an IP Address for your devices. Change the devices to have a fixed ip address. You may have to check the router for the default internal ip address, but it is probably 192.168.1.1 as the gateway. With the PC and laptop go to the control panel, then network connections, right clip on the connection and select properties, then scoll down the window until you see tcp/ip connection, select properties from the tab options below and set the ip address of each machine to 192.168.1.10, 192.168.1.11 and 192.168.1.12. set the gateway to 192.168.1.1 and set the dns ip to 192.168.1.1. Now if you have a different gateway address, use that as applied above. Save the settings and retry your connections.
Here is way you are probably having problems, wireless networks will drop and reconnect more often than a cable connection. If you were using just a cable connection, there would be less of a problem. When DHCP is being used and a computer drops the connection, it could get a totally different ip assignment the next time (a matter of less than a second of time). When that happens the original connection is lost. By fixing the ip address to be static, any time you reconnect via wireless, it uses exactly the same address, thus maintaining the connection.
Try it out and leave feedback if it works for you, otherwise send me the results of the test.
Feb 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
No wireless networks found in range
Are all the LEDs on the wireless router are on?
When you reset the wireless router wait at least 1/2 min before powering the router up.
Right click on the wireless connection and click on Repair, this will force the wireless router to issue a new IP address to the wireless card. If the the red x is still on the wireless conection then :-
To check if the wireless card can communicate with the wireless router, ping the IP address of the wireless router, (this is the IP address that is used to login and configure the wireless router) if you get no reply and all packets are lost, then connect a network cable from the laptop's RJ45 port to the wireless router's RJ45 port and do the ping test again.
If you still get no reply and lost packets then most likely you have a faulty wireless router.
Get back to me on the results of the tests and I can then advise what to do next.
Jul 16, 2009 | Dell Inspiron 9100 Notebook
SONY VAIO VGN-NR21Z DOESN'T SEE WIFI
Be sure that your wifi button is ON
Be sure that your wireless network is working
Check your wireless router settings
Check if you see any other wireless network available on your computer
Test connection, see if you pulled an IP address
  1. Go to the Windows desktop
  2. Select Start then Run
  3. In the text box type: cmd (WIN98/SE type command)
    At the command prompt type: ipconfig
4. What does it read as the IP address?
* If it reads 192.168. something dot something then you are pulling
an IP address and are connected to the network. The problem is
software related, check your firewall, and wireless card configuration.
Also check any WPA or WEP encryption keys. Check with the respective
manufactures.
* If it reads 0.0.0.0 for the IP address you are not connected to the network.
* Check your connection configuration and the adaptor.
* Check with the respective manufactures.
STEP TWO/ Basic troubleshooting continued....Testing the adaptor
1. Go to Windows desktop
A DOS window will open.
4. At the prompt type: ping 127.0.0.1 (reserved IP address for all adaptors)
5. Check the line that reads "packets sent = 4, Received = 4, Lost = 0
A. Zero is good, the adaptor is working. Again check the connection
configuration,and the adaptor configuration.
It may be a power issue especially with older or less expensive computers
or wireless cards.
* Check the antenna location, are you inside or outside, look for interference.
B. If it reads all 4 packets lost, the adaptor is not functioning.
* Check and update the drivers, Contact the respective manufactures.
* If it shows any number of packets lost (you are dropping packets)
it is an adaptor or signal strength issue (generally form the laptop side,
not being able to reach back) especially with older or less expensive
computers or wireless cards.
* Update the drivers
* Check antenna location, or distance from the signal
* Contact the respective manufactures.
Nov 06, 2008 | Computers & Internet
Acer Aspire One A150-1006 Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
