My lacie do a nois and dont whork i can't see my photos looks like electrical problem because sons like is triing to star but does't do nothing
    Brigadier General:
  • 4,090 Answers
Tek it tu acumputer ship fur rapir
Posted on Jul 30, 2009
HI MY ELECTRIC STARTER MOTOR STOP WORKING , WHEN I PRESS BUTTON ALL I GET IS A CLICK CLICK NOIS I HAVE PUT NEW RELAY S IN AND SAME THING HAPPENS . HELP PLEASE
Two other things to try. Make sure the battery terminal connectors are absolutely free of buildup. Then place your battery on a long slow charge. If it is not sealed, checkto make sure plates are all well covered with distilled water.
Finally, hook the battery charger up to the battery and move the selector up to start, say 50 amps. Try that. If you still have nothing but clicks, and all bolts and nuts are tight, time to look at the starter itself.
Sirwriter
Nov 04, 2009 | 2004 Derbi Senda SM 125 4T
I can not put ye low range,only higth range,i change the electonic 4x4 module and did not whork
What test or check did you do before you condemed the module? Do you have a system schematic? Electrical or mechanical issues. Got to split it out. Any vacuum hoses?
Sep 28, 2009 | 1991 Mazda Navajo
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My lacie is making clicking noise like clock
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Dec 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie brick 500 megs
nero has a program that ripps dvds ..4.3 gigs is huge file to look at alone open it.. I dont know the limits? for my biggest file was 800 megs mpg.
Feb 24, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie sounds like its working , but i can't find the icon on computer
Your hard dive is probably not formatted. You can check if your external hard drive is detected by the BIOS during bootup. You can also check this by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your lacie. If you dont then the drive is probably not detected. If you see, you can just partition it from here and it will appear in your my computer.
Dec 24, 2007 | LaCie (301015) 120 GB Hard Drive
Installation of Lightscribe
Loreen:
Check out this link, make sure that the software/tool or utilities are compatible to PC vista, please also check any firmware as well:
http://www.lacie.com/support/drivers/index.htm?id=10008
In Vista after the download is complete you might have to do this:
right click over the file and select run as administrator, (its strange but it depends upon the user trying to install software on your system).
Hope it helped!
Regards
Dec 16, 2007 | LaCie (300770) 250 GB Hard Drive
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
