Coffee Makers & Espresso Machines Logo
Can't get out of quantity water not reached.always goes to ventilate
2 Related Answers
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Jul 29, 2009
SOURCE: Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Bernie Corrigan
  • 487 Answers
  • Posted on May 05, 2015
SOURCE: if descale not function, how can I do?
Try reading the user manual. You can find it at: http://www.cerinicoffee.com/saeco-user-manuals-28/ or there is a video on how to do it at: https://www.youtube.com/watch?v=k6iGAQ5C8hs
1helpful
2answers
If descale not function, how can I do?
tip
Ventilate won't go away! WHY?
Why do I get Ventilate all the time?
The ventilate problem will always come back if the flow meter is restricted. If the flow meter is plugged it will never go away.What happens to cause this problem? Coffee grounds are the answer. If you remove the water tank, it exposes the water intake receptacle under the tank on top of the machine. The small opening in the receptacle that has a hose that goes to the flow meter that then goes to the pump intake. If some coffee particles fall into this opening when you are filling the bean hopper (and they do). When the pump is activated, it creates a suction, moving the water and anything in the hose to the flow meter. The flow meter has a small opening in the intake side. ). When the pump is activated, suction inside the flow meter creates a jet of water, which spins the little turbine inside. The turbine has a small magnet on top that passes a pick up sensor, which tells the computer that water is flowing. If the intake opening is restricted with coffee grounds, it will let some water flow but won't create a jet of water needed to spin the turbine. Water will come out of the steam wand, but won't spin the turbine and the ventilate signal will still be there. If the flow meter is slightly restricted, the pump can create enough suction to spin the turbine when there is no restrictions when the steam valve is just flowing water (priming), but when you try to steam or make coffee and the pump slows down, the jet of water stops and so does the turbine and the ventilate comes back.How to fix this problem? Answer, the flow meter has to be removed and cleaned, or just replaced.How to prevent this from happening? If you are working on the bean hopper (filling with beans) keep the water tank on and covered. This will prevent a bean chip from falling into the receptacle and getting to the flow meter. Do the same with the bean hopper. If you ware filling the water tank, keep the lid to the bean hopper on, so water doesn't spill into the bean hopper and ruin the grinder.bansheracer.jpg
tip
The washing machine is under filling water?
This problem is due to fault in the Water-level switch in washing machine.
The Water-level switch is the part in the washing machine that senses the filling water in the tub. When the water reaches to its required quantity the Water-level switch sends the command to stop the water supply. But if the Water-level switch is faulty. It will sense the wrong quantity of water in the machine. And makes the water supply stop bit early then required. So washer does not fills with required water .The Water-level switch is located at the bottom of the outer tub in the washing machine. Many a times removing and reconnecting the switch makes it proper. in other cases it needs to be replaced.
These will help. Thanks
on Mar 18, 2010 • Washing Machines
Low steam pressure
you have to put a litle quantity of vinegar about one botlle and rinse it trouuth hot water knob and then refill the water tank with fresh water and rinse it all water. That must help you. Instead of vinegar you can use liquid for descaling if you have.
1helpful
Pilot light keeps going out during hot days
Solution is probably better ventilation to gas water heater.
On hot days, heat and lack of ventilation can cause pilot outage.
Hot air causes oxygen molecules to move farther apart, and combustion is no longer supported so pilot goes out.
Open following links:
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
1helpful
2answers
Small ice cubes
The water is not reaching the ice maker in a sufficient quantity. If you have a water filter, change it. Thank you.
6helpful
3answers
Titanium plus stuck on rinsing cyle
go in the menu remove rince cycle after it say ventilate put water in container start machine open valve it should ventilate if it doesnt remove water container take turkey blaster put water in it put the blaster in the hole were the water container goes force pressure with the blaster at the same time open valve you vented by now put cointainer back fill with water enjoy thanks for using fixya pierre
10helpful
6answers
Stuck on Ventilation
I went through 3 machines (both Gaggia and Saeco--both have the same Rapid Steam system), hours of searching the Internet, and phone conversations with support(?) staff before I came up with what seems to be good options for both fixing the problem and then preventing it from being a problem again.
The Fix. Fixing the problem works better with two people, so I will refer to person 1 (P1) and person 2 (P2). To fix the problem: 1) P1 uses either a turkey baster or the small plastic (and leaky) pump packaged with the machine; 2) while the readout says "ventilate", P2 pushes the hot water button, then turns the machine off and removes the water tank; 3) P1 fills the plastic pump (or baster) with water and inserts it into the water intake valve (as best as you can, it doesn't fit perfectly); 4) P2 then turns the machine on and opens the steam wand while P1 pushes water into the intake using the plastic pump or baster; 5) as soon as P1 is finished, P2 turns off the steam valve. Repeat steps 3) through 5) until the machine has accepted 4-5 good pumps of water. If you get the "fill watertank" message, you must begin the entire process over again (if you get the "fill watertank" message every time, just keep following the process until you get the machine to accept 4-5 good pumps of water); 6) turn the machine off and reseat the water tank. 7) Turn the machine on, press the hot water button, and open the steam valve. It may take a minute, but you should finally get water. Run it until it becomes a steady stream, and then some more...about 8 ounces worth. I have found that this process doesn't always work if the machine is hot. When it's hot, it sometimes won't accept any water into the intake valve.
Prevention. To prevent the problem, I have been successful (so far) by: 1) after steaming milk, I push the hot water button and run hot water through the wand until it is a steady stream, and then about 4 oz more. 2) I always steam the milk first, then run hot water through the wand, and then make the espresso. 2) I always run water through the wand after making coffee.
This seems like a lot of steps, but it really doesn't take that long once it's part of your routine. I've been successful with this process for the last several day and before that, I was getting the ventilate message every time I tried to steam milk. I'm hoping it continues to work! It's really a shame that the technical staff have not come up with a better solution or, at the least, addressed the problems people are currently experiencing. When I called Saeco, they told me they didn't know why it as happening!
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
