Question about Tasco Target/Varmint 6-24x42mm Rifle Scope Mil Dot Reticle
Point of impact changes with every shot
Using a Tasco 3-9 x 40 scope on an 8 x 57 Mauser, the shots don't land anywhere near the target and never in the same place - that is not within a foot radius at only 25 yards. I installed better mounts, but that didn't help at all. Scope has hardly been used.
  • 20 Answers
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Posted on Aug 19, 2009
Testimonial: "That is a logical approach and sure to show where the problem lies. Shooting with the iron sights may also show a problem with the rifle or shooter."
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
If you use silencer, pit it off and try several shots because sometimes silencer is not well centered so the pellet hit the silencer. the most important in air rifle is barrel, try to shot at the sky with a good pellet and see the pellet trajectory trough the scope, if the pellet runs wobbling, spiraling etc there is something wrong with the barrel, check the crown. hope solve your problem
Posted on Oct 05, 2014
    Problem Solver:
Mildot firing solutionsd for a air gun. using Tasco 3-9x40 range finde scope
Posted on Jan 09, 2010
How do i zero my tasco silver antler rifle scope
Start out at 25 yards. the scope is I believe used 1/4 inch clicks. This is for 100 yards so 16 clicks will equal 1 inch at 25 yards. Fire three shoots from a solid rest. Measure the distance left or right and up or down from the desired point of impact. and move the setting in the desired direction. ie uo is moving the point of impact up from where it is. and left or right is the same. Next fire at the desired distance and move point of impact to where you want it at that distance. If the scope is wandering all over the target make sure the scope is not moving in the mounts. If it persist in changing point of impact send it back to tasco for a replacement as it has a loose recticle. Better yet I can recomend Leupold or Burris as a better alternative if they are in your budget. Not quite a S&B or Ziess but **** close for a lot less $$$$$
May 24, 2012 | Optics
Which direction do you turn windage and elevation
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 22, 2011 | Tasco 22 Riflescope
I shot my new 4.5x14x44mm conquest scope and tried to adjust the cross hairs according to my shots fired but the shots kept hitting in the same spot after a box of shells. i had it bore sited and i still...
Is the country of origin China.. Sounds like the reticle is stuck,, like from being dropped maybe in shipping. OK, Without any adjustments made shoot it one time, if you tap on the side of the scope, not the top of the turrets with a plastic/rubber hammer and point of impact changes (jumps) its faulty.. you cant fix it.
Feb 28, 2011 | Zeiss 4.5-14x44mm Conquest Target Rifle...
When I turn the turrets they go in the reverse direction, WHY
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Thats just the way it works. Point your right index finger at a spot on the wall, and sight down your finger like looking at sights, then take your left index finger and pretend it is a horizontal cross hair above your shooting finger, then raise your left finger a set amount above the right, then move your hands back to the shooting position not changing the distance in between, using your left finger now as the sight. You will see your shooting finger is now pointing lower than before. This is now the new point of impact, lower not higher. Hope this is clear as mud and helps Fix Ya up.
Dec 30, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Hi, I have a Tasco PDP3 redpoint on a 12 guage shotgun. It will group good for 3 shots then wonder off. I've found it to be loose somewhere on every occasion but the last one. My last shot hit the bullseye...
This does sound like it needs a bit of Loctite. But, You need to check this first, Is the scope being put in a bind due to heat from shooting. So, shoot for your group but wait say 7 to 8 minutes in between each shot. If in this case the gun stays on target every time, she is just getting hot and the heat is causing expansion in the mount / receiver area. If she jumps around during you timed shooting, then Loctite her in place, and Retry. If your sighting in slugs for deer hunting, your shots will always be from a cold gun, she needs to be on target cold not hot.
Dec 14, 2010 | Tasco ProPoint Red Dot Matte Red/Green Dot...
I have a weaver k-8 scope with adj. rings on front bezel ??????
the front ring is for adjusting point of impact at a given range,,,its called a "parallax ajustment" it corrects for the scopes inaccuracies over its full range say from 10 yds to 100 yds there a bit of a pain on a hunting rifle as you need to focus them every time and that slows down your shooting, when only a snap shot will get the kill you cant wate to mess about focusing the darm scope so i never use them on my rifles,,unless im target shooing,, or im snipping when i have time to take my shot,,,
(a head shot only!) only a parallax scope is spot on aim from 10yds to infinity
Nov 18, 2009 | Weaver Optics
Seting a scope
Theoretically, point of impact should not change if you change the xoom.In practice it sometimes does, but rarely to a noticable extent. 25 yards is about right for most pellet guns.BBs ane well known for curving and hooking, less so with pellets.Try different brands of pellets to see which ones work best in your gun.Lube the bore with an oily patch before shooting for best results.Enjoy
Mar 25, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
When you zoom your scope does the impact point change on the target? is that when you use mil dot?
No, the cross hairs remain fixed. The zoom serves only to magnify the field of view.
Aduz
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Tasco Target/Varmint 6-24x42mm Rifle Scope Mil Dot Reticle Logo
400 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Bill Laudeman
Bill Laudeman
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
