Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Pool heater shuts off itself before the set temp is reached
I have a Raypak RP2100 Gas Pool Heater. When I try to heat my spa, the heater works for about 20 minutes when it shuts off itself but before the set temperature is reached. The water is heated up from 84F to 90F, but well short of 96F set point. The strange thing is that it shuts off the power to the controller so the LCD display goes dark and I cannot restart it. Turning off/on the power switch cannot bring the controller back to life till next morning.
What's going on here? Could it be a faulty Hi limit switch?? Could someone help, PLEASE?! -Jeff
    Champion:
  • 246 Answers
Need new board control kit
Posted on Aug 25, 2009
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Burner stays on, no control
check temp sensor if not reading that its hot enough it will keep running if ok see if not calling for heat if not gas valve sticking open replace
May 21, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
I have a raypak heater when i fire it up the water temp go's up real fast
I assume this is on a swimming pool. It might depend on how it is plumbed in. Quite often, there is a bypass valve allowing the pool water to bypass the heater incase it's being serviced, or a leak etc. You would close inlet and outlet valves to heater and open the bypass. This would isolate the heater. If you have the bypass open while heating, you will reduce (or eliminate) the flow through the heater. This will allow the water in the heater to heat very fast, and lets be glad there's a temp control or your plumbing would melt. These heaters should have full flow through the heater, and you'll see min temp rise per pass.
Jun 30, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heater will not heat to set temperature and board goes blank
bad temp sensor or transformer if voltage coming out after it goes out bad board if no voltage bad transformer
May 12, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak RP2100 pool heater set temperature stuck on 50 degrees
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Jun 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
391 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
