Question about Epson Stylus Photo RX500 Printer
Problem printing When I print anything but text the alignment is off and they look like someone smugged them. I've tried using the alignment feature on my printer (Epson Stylus Photo RX 500) but it doesn't seem to help. So now I am at a loss. What can I do now?
  • 248 Answers
Re: Problem printing
Turn off high speed printing from the printer properties... This will allow a more stable type of printing... If you have windows, the printer properties in in the control panel's printers folder.
Posted on Jun 30, 2008
0 characters
3 Points
I think your text document didn't fit the page. I have done that before. It overruns and the extra becomes the lines inbetween. To fix this use microsoft publisher to print it so that you can choose the paper size and the borders and fit the document within the space allowed.
Nov 24, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Erratic print with canon ip 4300 printer
The document should be formatted as a table with text inserted rather that a group of text boxes.
Nov 24, 2013 | Canon Printers & Copiers
Epson picturemate photos printing all black
Maybe you set printer options to print color as black.
Aug 18, 2012 | Epson PictureMate InkJet Photo Printer
My Lexmark x4690 all-in-one printer is not printing. It prints if I go through the touch pad menu on the printer and print an alignment page but not if I try to print anything from my computer. Text,...
You may need to uninstall the existing X4690 driver first before installing it's driver for Windows 7. Follow the instructions in this artricle on How to Uninstall Lexmark Printers. Once driver is uninstalled, reboot pc when prompted. Reinstall using the driver for Windows 7 from the Lexmark website at:
- Lexmark X4690 Driver for Windows 7 32-bit - Lexmark X4690 Driver for Windows 7 64-bit
Hope this helps.
Feb 25, 2011 | Lexmark X4690 Wireless InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Icant get it to print anything cartiages are full and it goes though the process like its printing but paper is blank
Hello windymejia4,
Try these things. 1. is the tape still covering cartidges? Take off and try to print? 2. Is the right print drve picked? control panel, printer , make sure your printer is picked as defualt. 3. did you allow printer to do alignment? 4. see if ink will smug your finger with ink, when one of the cartdges is taken out? If not use a pencil eraser and erase the mental tip where ink is suppose to come out? Is this a fixya?
Apr 28, 2008 | Printers & Copiers
Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
Alignment failure
Hi kelbel, Here is the HP link the software downloads for your device. Click on the link for your operating system and select either the full feature or basic feature software download. Your CD had the full feature but at 276MB you may prefer the 37MB basic download instead. Let us know if you need anything else and don?t forget to rate the post.
Jan 05, 2007 | HP Photosmart 2610 All-In-One InkJet...
Epson Stylus Photo RX500 Printer Logo
96 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
