Question about Campbell Hausfeld Maxus 45 Lb Pressure Feed Sandblaster with Steel Hopper MXS21001
No Sand or Air is coming out when trigger is pulled
  • 34 Answers
The sandblaster relies on a clear and unkinked line from the sand tank to '**** up' the sand and drive it out the nozzle with the air flow.
-Do you have air pressure at the nozzle? It may be obvious, but you need good air pressure. Pulling the trigger, you should get air out of the nozzle. If you don't, start with the air compressor.
-The sand needs to be dry and unclogged. Dump all the sand out of the container, and pour it back in through the filter screen.
Posted on Aug 13, 2009
Dewalt D51238 not firing when trigger pulled but air does come out?
Remove the head and lube the headvalve with white grease. If gun still does not fire and makes air noise at the trigger valve then orings within the trigger valve are worn. Replace the trigger valve or if you have a source for small orings, just replace the two orings on the metal stem (2mm x 1.5mm). Dewalt uses vinyl orings on the stem that fail. Replace with buna. Good luck
Oct 13, 2014 | Air Tools & Compressors
I have a bostitch n62fn finish nailer that wont fire. when i pull the trigger, air comes out of the trigger assymbly. the gun is not jammed, and is receiving correct air pressure.
this may sound stupid but are you pushing it against the wood when pulling the trigger. it has a safety switch on the front so it will not work just by pulling the trigger.
Nov 12, 2011 | Stanley Bostitch N62fn Finish Nailer Parts...
Bostitch RN46 will not fire nail, only releases air when trigger is held and firing tip is touched to surface of material. Any ideas on what is wrong?
Gun will not fire if air is leaking past orings in head /headvalve or safety /trigger is not pushing trigger pin all the way into trigger valve. Test: Remove trigger to expose trigger valve pin. Remove nails. Place nose of gun against thick rubber mat or coiled rubber hose to absorb blow of driver. Very quickly and deliberately press trigger pin all the way in. If gun fires, safety foo or trigger is not pushing trigger pin all the way in. Make adjustments or replace worn parts. If gun still does not fire, remove head and pull out headvalve. Apply lots of silicone paste lube on the orings and the surface of the head where orings make contact. Reinstall head and test as above. If the gun fires then orings were leaking. Replace orings and sand any scratches on body of cap with very fine sand paper. Parts are at www.toolpartsdirect.com Good luck
Mar 06, 2011 | Stanley Factory Reconditioned Bostitch...
My paslode t250-f16 doesn't fire when triggered-- only feel air coming from around the trigger
When headvalve orings are leaking, the nailer will not fire. Remove head and also remove the headvalve. Examine the surface/s where orings make contact looking for scratches. Sand surface with 300 grit paper until smooth. Reinstall parts using silicone paste lube. If head is too scratched /worn, also replace with new including orings as needed. Good luck
Jan 29, 2011 | Porter Air Tools & Compressors
NRA833AA model. air is leaking out of trigger valve & will not fire. require manual to check operation.
Here is a link to hitachi web site listing for your gun. Look at the bottom of the page for pdf files of parts lists and manual.
http://www.hitachipowertools.com/store_item.php?iID=154&arrPath=1,9,43,p154,
There are two areas around trigger that can leak air. Spray soapy water on trigger stem and/or plunger valve. If leak is at trigger stem check vinyl ball. If leak is at plunger valve, most likely worn or broken oring inside of gun. Remove head and pull outer ring to reveal two orings. A worn outer oring will cause leak at plunger. If orings are ok on outer ring, pull cylinder and check for scratches where orings contact. If scratched, sand with 400 grit paper untill smooth and repack gun with oring kit. Good luck.
Jan 09, 2011 | Hitachi NR83AA3 3 1/4" Clipped Head...
Bostich rn46 . gun will work fine for awhile, then when i pull the trigger, all i get is air coming out of the trigger. i've put a rebuild kit in and i've also put a new trigger assembly in it. didn't...
Assuming that there are no leaks, remove head and pull headvalve. Look for fine scratches where oring contacts head. If there is a deep groove worn into head or scratched, sand with 400 grit paper to restore smooth surface. If badly worn replace head. Reinstall parts using silicone paste (looks like vaseline, sold at lowes in the plumbing department, used for faucet orings) )
Oct 31, 2010 | Stanley Bostitch Rn461 Gun Coil Roofing...
Have power to unit. sounds like it is working. pull trigger on the gun and hardly any water comes out. turn it off and there is pressure coming out
Have you tried pulling the spray nozzle tip off and checking it for blockage? The spray tips have a tiny hole for the water to pass through, and sometimes a grain of sand or debris will get stuck inside the nozzle and restrict the water flow. Something to check.
May 22, 2010 | Garden
Not shooting
Trigger Valve needs replacing. Part Number is FA205BA1. The valve comes with instructions, its a pretty easy fix. Any BBostitch dealer should be able to get you one.
Mar 11, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Campbell Hausfeld Maxus 45 Lb Pressure Feed Sandblaster with Steel Hopper MXS21001 Logo
175 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
rjivaro
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
