Question about HP DeskJet 3650 InkJet Printer
Printer does not turn on!! it hs been disconected for over a year and now that i've conected it, it doesn't turn on!
    Problem Solver:
Have you tried to unplug cables and power? Try and see if it will work then.
If not, if you're savy with computers....uninstall printer and then reinstall.
See if that helps.
Posted on Jul 30, 2009
What does this code mean E000747-3C00
Main controller PCB error.Turn the main power off and on,disconect and conect PCB controller,replace CB controller
Aug 20, 2014 | Canon C3380i Color Copier
Printer Epson L110 doesnt work with Asus X750 series
It's not the printer it's the program you're opening the file in.
Apr 06, 2014 | ASUS Computers & Internet
I have a Singer Sewing Machine #9444. There is no electrical getting to my machine since the light doesn't work and the foot pedal doesn't work after I turn on the machine
Try replacing the light bulb or rerouting the wire so it won't be affected by the light bulb or the foot pedle. Becarefull though because if you rerout the the wireing in the foot pedle you're taking away the off/on swich so it'll stay on. You may want to open up the foot pedle and see if there is anything loose, not conected or broken. The pedal is used as an on/off swich so it may just be stuck in the off position and not making contact when you press down on it so it won't turn on.
If you can't fined a blulb for it by the way you can disconect the socket where you screw it in and install a new one. Make sure the new one will fit in the same hole though. Then it should be easy finding a bulb for it. PLEASE MAKE SURE THE MACHINE IS DISCONECTED BEFOR YOU DO ANY OF THESE THINGS. Good luck!
Sep 30, 2011 | Sewing Machines
I had to disconect the printer to move it I've conected it all back up it has power but the computer keeps telling me it's offline. Help please, Ive run my trouble shooter and it is telling me that...
Use Print Flush 1.3 to fix it:
Fix your printer with this small utility!
Has your printer quit working? Did you try to cancel a job and it broke the printer completely? I always do that. And the method to fix it usually involves rebooting, restarting the print spooler, trashing junk print files, and sometimes even more. Not anymore.
Print Flush has a simple function: clean the print spool. If your printer's driver is incorrectly installed, Print Flush cannot help you. If you have used your printer before and it worked fine then, but it doesn't now, Print Flush can probably help you.
It also works with Vista.
http://www.bradkovach.com/printflush/
  1. Save somewhere where you can find it.
  2. If you downloaded the zipped version... Unzip the file to the desktop or something
  3. Double-click the file
  4. Try printing again!
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Jul 18, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Hi my electrical engineer disconect my battery's
Following may be problem.Please check
1.Check the charge in the battery.
2.The terminals are properly and correctly connected.
Thanx
Jul 07, 2010 | Cars & Trucks
Possable broken/Disconected wire
hope you have checked the obvious first ..the plug are all the conections tight including the fuse? if so check the vac's switch for loose conections .lets face it the mains feeds the switch the switch feeds the motor unless you have a speed switch. sounds like a fault that could be cured with a bit of investigation good luck farr64
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
CS pro EP6001
Put copier off Disconect sorter cable then turn copier on if it work properly put it again off then conect the sorter
Jan 12, 2009 | Office Equipment & Supplies
Help
wat is the make and model of the router?
try to upgrade the firmware on router to resolve wireless problems
Sep 06, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
Printer won't print, loaded up
at first you disconect your printer cable. and reset your laptop then conect printer cable and anstall driver auto.setup printer driver and chack test print.
Jan 22, 2008 | Canon PIXMA iP2000 InkJet Printer
HP DeskJet 3650 InkJet Printer Logo
75 people viewed this question
Seeker5211
Seeker5211
