We need help removing the front panel from our sony kds50a200 tv. We have unscrewed the back screws but the bottom is still fastened somehow and cannot figure it out. We need help.
  • 90 Answers
Pull hard! It pops off.
Posted on Jul 30, 2009
How do I finish removing the rear half-cabinet of a Zanussi FL828 washing machine?
Carboran Tub
1. Remove the ring fastening the door gasket and disengage said gasket from the front panel.
2. Disconnect the tubes from the tub (soap dispenser-to-tub, vapour discharge, tub-to-filter housing, etc...)
3. Disconnect all component wiring connectors fastened to tub (motor, heating element, thermostats) and adjustable thermostat bulb, if any.
4. Remove the motor
5. Unscrew the four fastening screws and remove the back counter weights (only on machines provided with such counter weights).
6. Remove the two pins fastening schock absorbers to the tub.
7. Lay the machine flat front-face downwards (placing in-between some means of protections, such as polystyrene, cardboard and the like, so as not to scratch the cabinet).
8. Disengage the tub's suspension springs from the cross-bar with the aid of a piece of string.
9. Remove the tub from the washing machine.
10. Remove the driven pulley.
11. Remove the motor (if you doesn't before)
12. Remove the 17 screws which fasten together the two shells.
13. Slide out the drum.
Dado
Jun 17, 2015 | Zanussi Washing Machines
I have sony tv sets model kf-60xbr800 and manufactured in 2003. My bulb blown out which number is xl-2000u. how to replace new bulb?
Obviously you should purchase the new bulb. (here: http://tinyurl.com/3chwjes ) 1. unscrew the four Phillips head screws from the front (as you see the bulb) 2. slide the front out. 3. unscrew the Phillips head screw connecting the circuit 4. with pliers take off the nut attaching the other circuit 5. remove the wire holder 6. remove both golden fasteners. READY FOR NEW BULB. it is recommended to use a glove while touching the new bulb. 7. go backwards trough the steps until assembled!
Aug 20, 2011 | Sony XL-2000U Projector Lamp for XBR800...
I need to know how to disassembly the instrument panel of f-150 1997
Disconnect the Ford's negative battery cable. Turn the truck's front wheels straight ahead and then lock the steering column. Remove the A-pillars' trim by removing the screw covers and then unscrewing the mounting fasteners.
Remove the center console if equipped by unfastening the nearby trim panels, prying off the shifter trim panel, disconnecting the shifter cable and unfastening the console. Remove the steering wheel, then unfasten and remove the steering column covers, starting with the lower cover.
Remove the instrument cluster. Unscrew and pry off the knee bolster with the aid of a flat-blade tool, then unscrew and remove the instrument cluster bezel in a similar way. Disconnect the electrical connectors, remove the cluster's mounting bolts and remove the cluster--you'll need to disconnect the gear position indicator on an automatic transmission.
Remove the glove box by opening the door, pressing on the sides of the compartment bin together, pulling the door down and removing the fasteners at the bottom. Remove the center brace cover, center bezel and upper finish panel by removing their fasteners or prying them off their clips.
Detach the end caps to the panel with a trim stick or flat-bladed tool, then detach the hood release by removing its screw. Pry off the scuff plates and kick panels from the door frame. Pry up the defrost grilles with the same flat tool.
Disconnect the steering column shaft. Disconnect the electrical connectors from the column's harness, detach the shift cable and transmission indicator cable if you have automatic transmission, remove the pinch bolt from the intermediate shaft coupler and separate the intermediate shaft from the steering shaft.
Disconnect all remaining electrical connectors to the panel and unbolt all fasteners for the panel around the top, left and right sides and the ends along with the brackets at the center. Lift and pull the panel away from the windshield with an assistant's help, disconnect all remaining connectors and carry the panel out the driver's door.
Good luck.
Nov 07, 2010 | 1997 Ford F150 Regular Cab
How to replace rear projection lamp ?
ok first put the back back on and all screws back in unit. The bulb is located on the front of this TV. Now on the back of the unit on each side there is 1 plastic straight head screw on each side of the back of the tv turn these and on the front where the power button is thats a panel that pulls off the bulb is right behind that panel u have to unscrew to phillips screws on bulb case and it pulls right out, the front panel sometimes takes a good little tug to pop it loose just make sure those plastic screws on each side right on the back of tv are loose first. Hope this helps good luck.
Apr 08, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do I remove the stand of the Sony Bravia XBR KDL-V40XBR1 so i can wall-mount the tv?
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Nov 26, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Removing the front panel -bulb replacement
There is no other screws other then at corners at back of TV that you have already removed/ loosen.
Please pull lower front from its top corners as its lower part has hooks with bottom of TV front.
Below image will help you to remove front panel for lamp replacement in this TV..
Thanks.
Sep 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony bravia 50 in lcd rear projection tv picture dark most of the time
take out screws ob back side around the edges not bottom. the grill that covers the speakers comes off by taking out screws on back in the middle of round knobs after screw is removed unscrew knob. then remove screws next to speakers then remove front of tv clean mirror in back. if that dosent work replace bulb.
Nov 20, 2008 | Televison & Video
Where to locate the lamp assembly
Look at the TV from the front, on the stand just under the TV there is a panel. Reach around the ends of the panel and you will feel the fasteners that hold the panel on. Unscrew the fasteners and the front panel comes off and you will see the lamp in the front center.
Sep 20, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
Top Televison & Video Experts
