Question about Polaris Pb460 Polaris Booster Pump Replacement Impeller
Polaris pump not moving my polaris impeller in good shape
  • 990 Answers
Did you ck your finger screen? ether in the wall or in the hose.
Posted on Oct 04, 2009
Impeller spins when i'm holding the shaft. what would cause this problem or is it? i have no pressure.
Late answer but might help someone else out.
There is a nut molded into the impeller. If the threads are stripped or damaged the motor shaft will spin and not move the impeller. You'll have to take the pump apart to diagnose.
Apr 30, 2012 | Polaris Pb4 - 60 Booster Pump
Pump seems to start ok - 240 volts - shaft spins but not enough water pressure to move the polaris cleaner?
It sounds like you could have some debris stuck in the impeller on this pump. This is a common problem and anything that gets past the pool filter can end up stuck in this pump.
Sep 03, 2011 | Polaris Pb4 - 60 Booster Pump
There is a leak from the front on the pump. A steady drip but the cleaner is still moving and working properly. The front is held on by a number of 1/2 or 3/8 inch nuts. The drip is from the other end...
I recently had this happen to a fairly new pb-4 that ran dry and overheated for about an hour before I noticed it. I disassembled the volute and impeller on the front of the shaft to look at the condition of the impeller and shaft seal. There are several youtube videos that detail the shaft seal replacement. I ended up having to replace the impeller as well as the shaft seal due to the impeller being deformed. Cost me about $35 for both the impeller and seal.
Jun 17, 2011 | Polaris Pb4 - 60 Booster Pump
I am having difficulty removing the impeller on my Polaris PB4 Booster pump. I removed the seal plate and held the motor and attempted to turn the impeller counterclockwise. Can't get the impeller to...
For an impeller really stuck on the motor shaft you need to pull the motor thru-bolts and remove the rotor with the pump still attached from the stator. Lock the rotor in a vice and turn the impeller off with a large set of channel locks or a large strap wrench.
John
Nov 07, 2010 | Polaris Pb460 Polaris Booster Pump...
No spark
Not enough info here. I can help you with any problem with your Polaris booster pump, or just about any impeller issue with most pool pumps. Please respond to clarification, or post further question in the comments. Thanks
Sep 21, 2010 | Polaris Pb460 Polaris Booster Pump...
I have a Polaris PB4-60 Booster Pump with a leaking seal. I have removed the Volute and removed the 4 bolts that hold the bracket to the motor. How do I remove the impeller? At the store they told me it...
You need to lock the other end of the motor shaft and then spin off the impeller. If you would like a quote on the replacement seal, contact us at www.arrowpools.net
Jul 11, 2009 | Polaris Pb460 Polaris Booster Pump...
Polaris Pb460 Polaris Booster Pump Replacement Impeller Logo
118 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
