Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
My engine runs but when I let off of the clutch it dies. What is causing this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Check the plug on the seat switch,unplug it and plug it back in, if it is not securely plugged a safety spring in the plug will activate and short the ignition out,this is designed by the manufacturer to prevent unhooking the seat switch safety system. If you follow the white wires from the ignition switch they will lead you to two other switchees in the system,one on the mower engage clutch and one on the foot pedal,make sure these are plugged in also, if still no go one of the switches is bad.
Posted on Jul 30, 2009
Yamaha TDM 850 engine dies when clutch lever is released
Hi, Marcus the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Stalls When Release The Clutch Lever
The 1299 Engine dies when pulling the clutch lever in
Yamaha TDM850 1996 Service Manual
OEM parts for Yamaha
YAMAHA TDM850 Owner Manual
Aug 18, 2017 | 1994 Yamaha TDM 850
Why when i push in clutch on 99 dogde ram it dies
But it doesn't die if you quickly shift into neutral and let it run in neutral?
If it runs in neutral but then dies when you put in the clutch, it is then a problem about the electrical/processor, because nothing mechanical changes that could affect the engine like adding load.
Sep 01, 2014 | Cars & Trucks
Why does engine die
The clutch is not totally disingauging.
Jul 28, 2014 | Polaris 2009 Sportsman 850 EFI XP With EPS
My 2000 ford focus does good, til i change into 2nd gear, then from 2nd through 5th gears, it jerks and barely runs. and when it gets real bad, it causes the clutch to slip, what could be the cause of...
So you can race the engine in neutral, and no problem with it trying to die? If that's so, I think you need a clutch job. A clutch disc contaminated with oil or grease will cause jerking and slipping.
Sep 14, 2012 | Ford Focus Cars & Trucks
22r engine dies when clutch pushed in
CHECK THE IDLE AIR CONTROL VALVE IT TAKES OVER WHEN YOU LET OFF GAS MAY BE STICKING
Nov 15, 2011 | 1983 Toyota Pickup
The van starts fine when at non operating temperature but after it runs and warms up and i turn it off THEN try to start it i have to wait for it to cool down to get it to start.(it's just warm not...
On engines with belt-driven cooling fans, a fan clutch is often used to save energy and reduce noise. The fan clutch disengages slows or disengages the engine's cooling fan when extra cooling isn't needed. The fan pulls air through the radiator and air conditioning condenser when the vehicle isn't moving fast enough to provide adequate airflow for cooling. A fan can eat up anywhere from a couple of horsepower up to 12 or 15 hp on a big V8, so by reducing the parasitic horsepower loss on the engine the fan clutch makes a noticeable difference in fuel economy.
A slipping fan clutch is often overlooked as the cause of an engine overheating problem.
As a fan clutch ages, fluid deterioration gradually causes an increase in slippage (about 200 rpm per year). After a number of years of service, the clutch may slip so badly that the fan can't keep up with the cooling needs of the engine and the engine overheats. At this point, replacement is often necessary.
Other signs of fan cluch failure would include any looseness in the clutch (check for fan wobble), or oil streaks radiating outward from the clutch hub.
If the clutch is binding, the fan may not release causing excessive cooling and noise, especially at highway speeds
CHECKING THE FAN CLUTCH
A good clutch should offer a certain amount of resistance when spun by hand (engine off, of course!). But if the fan spins with little resistance (more than 1 to 1-1/2 turns), the fan clutch is slipping too much and needs to be replaced.
If the fan binds, does not turn or offers a lot of resistance, it has seized and also needs to be replaced.
Fan speed can also be checked with an optical tachometer, by marking one of the fan blades with chalk and using a timing light to observe speed changes, and/or listening for changes in fan noise as engine speed changes.
You should also try to wiggle the fan blades by hand. If there is any wobble in the fan, there is a bad bearing in the fan clutch, or a worn bearing on the water pump shaft. A bad water pump bearing will usually cause the water pump to leak and/or make noise, but not always. Remove the fan clutch and see if the play is in the water pump shaft. If it feels tight (no play or wobble), replace the fan clutch.
I posted this to another Ford Problem and I believe it applies to you as well.
This is a shot in the dark with out running diagnostics myself but here it goes, I had a 1988 Cavalier that would just die while I was driving it. On short drives, in the morning, when the engine was cool... it would not die. It would only die after the engine heated up to a certain point.
I took it all over the place to see what the problem was and nobody could figure it out, until finally I took it to my local Firestone shop and they had a special diagnostic tool that checked all of the electrical connections and low and behold I had a misc. wire that crossed the back of my engine from one side of the engine bay to the other. This wire was melted to my engine block and when the engine heated up to a certain point the wire would short out.
After they pinpointed the wire they replaced it with an in-tact wire and it worked beautifully.
Again, I am not stating that this is for sure your problem, but take it from me that there are better diagnostics to run then your standard error code ODB II dump.
Hope that helps and let me know if there are any developments.
Brian
May 26, 2011 | 1995 Ford Econoline
Engine starts and runs with clutch pressed down and dies when clutch is released. what causes this?
Never been in on this kind of deal yet but, I'd check out that seat safety switch. That clutch switch should only close a circuit to the starter so it will start. I see no reason for that to be wired in to the ignition in anyway.
Good luck,
ballping
Jul 22, 2010 | Craftsman Garden
Engine stalls when put into gear, idle fines in park
This is a comon problem with GM cars.Most likely cause is the torqe converter clutch lock up solenoid.
Mar 04, 2009 | 1996 Chevrolet Cavalier
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
180 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
