Question about Kenmore Washing Machines
I get an F- code and nothing else what does this mean?
  • 2,841 Answers
Sears sells washing machine under the Kenmore brand but they do not manufacture washers. Your Kenmore was made by someone else. Go to this website. http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html#Sears Look under the Sears/Kenmore section and find your serial #. This will tell you who manufactured your machine. Then look under that brand to find the code and what it means. Hope this is helpful.
Posted on Dec 09, 2009
Code reading doiclr
Hi Anonymous, the code is actually d01clr. All " d " codes, and there are ten of them, have to do with the speedometer and speed sensor only. clr means " clear " so d01clr means the speedometer has no d01 codes meaning that part of the system has nothing to report. If it "did" have something set, it only means that the perameters the computer excepts as normal has been breeched and d01 has to do with the speed sensor power output shorted low involving a red wire. Could be nothing more than a power spike. Good luck
Apr 11, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
What does the F30 code mean?
F30 code refers to a Dispensor Motor not engaging correctly. Start you cycle and usually you will hear clicking as the motor attempts to engage.
Jan 22, 2012 | Whirlpool WFW8300SW
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
What does Code LD mean? When it is supposed to spin out, It stops and I get a code LD.
LD is a long drain code usually mean something is in the drain line or pump area. Check thes areas first. If nothing blocking them then the pump is going out.
Dec 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
I have two fault codes 00172 and 00111 what do
the 172 is saying the system was or is lean, the 111 cose is a system pass code meaning nothing is wrong, your test cycle ends with this code meaning no more codes present. As for the 172 code, check your intake tube between the air filter and the manifold for cracks/leaks, also check for any other vacuum leaks. Clear codes by disconnecting the battery positive cable for at least 10 seconds. Hope this helps, let me know.
Mar 17, 2010 | 1994 Ford Escort
I used an SCT livewire tuner and it came up with a trouble code of P1000. What does this code mean?
P1000 code means "testing incomplete". You can not reset this code, drive the vehicle and code should clear when the system recovers all testing data.
This can occur when the battery is disconnected for an extended period of time.
Nov 08, 2009 | 2006 Ford Mustang
Check engine light is on does this generally mean
IF UR CHECK ENGINE LIGHT IS ON THE VEHICLE SHOULD GO ON A CODE READER SOMETIMES A LIGHT CAN COME ON 4 ONE SMALL GLITCH AND MEAN NOTHING GET THE CODE READ BEFORE SPENDING MONEY
Oct 17, 2009 | 2002 Mitsubishi Diamante
What does the code 1255 mean in a 1995 Intrepid?
That's probably code 12 & 55 which means 12-battery has been disconnected recently, and 55 is end of codes. In other words, nothing to worry about. Are you having any problems?
Jul 06, 2009 | 1995 Dodge Intrepid
Washing Machines Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
