Question about Canon PIXMA MP780 All-In-One InkJet Printer
The printer does not print or copy. The inkjet tray mechanism does not appear to move or sounds that it is stuck. The warning light is flashing. There is plenty of ink. This happened after trying to change inkjet, leaving the door/flap open for long period of time.
Hoe do i put my printer back on line
Posted on Jul 30, 2009
My alarm light and copy light are flashing and the display says error code 6A00 I have tried turning the machine and computer off and then rebooting , but it didn't solve the problem
I had this error (6A00) on a MP760 after a couple of months of not using it.
I switched it off, opened the lid and manually slid the cartridge-tray to the left.
Then I used a piece of tissue to clean the base-pad where the heads are stored. It turned out to be stuck in a kind of upward position and somehow the mechanism that moves the tray is released so nothing happens when you switch on the printer.
Touching it snapped it loose. Remove all ink residue, move the tray back to its most right position and close everything.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Lockup
You need to do some cleaning on this printer, because that causes it not to work , you can take the parts off from the printer and use alcohol to clean the dirty parts of the printer..
Hope that helps.............
Sep 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Two red lights flashing on & off
This error means that some mechanical parts of your printer is in trouble. This could be some of the causes:
1. The print head is stuck somewhere or is unable to move because of some blockage in the printer's bay.
2. If you are using a Continuous Ink System, then the tubes might have blocked the print heads from moving.
To resolve, turn OFF your printer. Remove such blockage then turn the printer back ON.
Regards,
JR
Oct 26, 2010 | Epson Stylus Photo R220 InkJet Printer
Flashing lights won't stop
Hi Good day!! This error means that some mechanical parts of your printer is in trouble. This could be some of the causes:
Regards,
JR
Oct 21, 2010 | Epson Stylus 680 InkJet Color Printer
Last page stuck in printer. I manually pulled the paper free. Printer will not print. Lower two lights blink in phase. Unplugged and replugged. Still same light pattern and no print. inspected inside and...
First open rear cover and make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the carriage lift mechanism for correctly moving. If this not help your printer need service.
Nov 09, 2009 | HP DeskJet 5550 InkJet Printer
Canon MP830 error code 6A00
HI,
Please the pixma off and open the lid.Now manually slide the cartridge-tray to the left.
Use a piece of tissue to clean the base-pad where the heads are stored.See if it is stuck in a kind of upward position and look if the mechanism that moves the tray is released if not then touch it and it will be loose. Remove all ink residue, move the tray back to its most right position and close everything.
Let me know if you still get the same error.
Thank you
Aug 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Won't print - just flashes it's lights at me!
I tried what phrek said (" Pressing the flashing buttons simultaneously, evokes the printer to spit out an internal diagnostic page ..."), but after the diagnostic page printed out the printer worked fine again.
Thanks for the help, and hopefully things work out for the rest of you as well.
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Lexmark aio will not scan does everything else!
all these problems seem to be with Lexmark equipment
Dont see any Epson problems, story here somewhere
Feb 14, 2008 | Lexmark X1270 All-In-One InkJet Printer
HP c3180 inkjet printer problem
apply two or three drops of 3 in 1 oil to top of the big silver rod (inside printer cover)on which the ink cartridges ride.
UNPLUG RESTART AND Print
Dec 25, 2007 | HP Photosmart C3180 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
69 people viewed this question
old marine
old marine
