SOURCE: Won't PDF to email
I had the same issue when migrating between exchange servers. basically the scanner settings were pointing to the old exchange servers IP. I set that to the new IP and it resolved the issue.
SOURCE: Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
SOURCE: Imagerunner 2220i - Scan-to-email Configuration
http to the machine and its under general settings can't think of exactly where off the top of my head
SOURCE: Entering email destinations in scan mode
Thru web image monitor, type the ip address into a web browser (upper portion) so if ip is 178.005.045.100 type in 178.5.45.100, sometimes the 0's wont allow you in. Log in as an administrator. name is admin no password. and add your name and display name and in the lower portion the e-mail address. -Carl
SOURCE: add a new email address
if you are connected thru the network the best way is to start Top access then click registration tab,then address book. on that page you will find add address.
or on the machine press "user functions",then tab address,then press address book,find free slot, press entry. there u will find space everything. after U enter just confirm that and that it.
