Question about Dishwashers
My Whirlpool dishwasher stutters loudly during wash cycle. It's an intermittent thing, in the sense that sometimes when i run the dishwasher it doesn't do it at all. But also in the sense that when it does do it, it's for like a couple of seconds, then fine for a bit, then stutters again for a few seconds, fine for a minute etc etc. Sound is coming from inside, kind of like the power is turning on and off rapidly. It's a Whirlpool ADP-8540 Stainless Steel (Made in Germany)
  • 423 Answers
A symptom like this is commonly caused by a failing wash pump motor. If you are having this problem and the dishes are not getting as clean as they used to, the motor is most likely the problem.
Posted on Aug 12, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
Noisy Dishwasher
it is a capacitor to start the motor for the next cycle. I think it is inside the door. you may have to call a tech.
May 19, 2013 | Whirlpool GU2300XTVQ Builtin Dishwasher
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
i have seen these test good but be just out of calibration enough to cause long run times.
you can try to change it yourself or have the service company try that instead of a new board and panel.
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Loud Whining/Humming noise while washing
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Feb 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
427 people viewed this question
Top Dishwashers Experts
