Question about Dometic Rooftop RV Air Conditioner
Dometic rooftop a/c
Same as the other. Runs for a bit with a/c on the compressor doesnot come back on after a cycle and thermostat flashes a/c
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
LOW VOLTAGE PROBLEM
Posted on Aug 01, 2009
Why is dometic ac not cooling
thermostat or capacitor- compressor issue
Jun 09, 2014 | Dometic Rooftop RV Air Conditioner
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
AC runs constantly. Can it run on automatic?
fan should be in auto position on stat. if still runs fan relay stuck in
Aug 18, 2012 | Dometic Rooftop RV Air Conditioner
Ac runs for a minute cycles off for a minute than runs for a minute than blows breaker
that sounds like you have a electrical problem ,which is in the compressor.Its grounded out to the casin ,the fan comes on then the compressor cycles on an cuts the unit off, thens tries to crank back up but trips the breaker....
May 16, 2010 | Dometic Rooftop RV Air Conditioner
The airconditioner runs and blows cold ai. When
Hi, the only thing that could cause this to happen would be the thermostat. This is the main part that controls the roof top unit, getting its signal from the stat to come on and maintain the correct temperature. I would replace it with the same type and this will solve your problem. The only other thing that would cause any unit to cycle like this is if you had bad thermostat wiring touching together some where. I don't think this is the problem with yours though. With the stat off and it still cycles on, this tells me for sure it is the stat. Change it out and you will be good again.
Sincerely,
Shastalaker7
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
AC is off but compressor cycles periodically
most likely your compressor contact is stuck closed, and will need to be replaced. if the fan also runs when the compressor comes on you may have a short between the t-stat and unit. hope this helps.
Jun 14, 2009 | Dometic Rooftop RV Air Conditioner
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
95 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
