SOURCE: lock won`t open
Look for a button or sensor which turns the light off or which the door would press when closed.
If you find it hold it down for a minute, then let go this should reset the lock
SOURCE: LE message, will not lock the door - Daewoo front load
Hello there:
This is a fairly common problem with these newer machines Here are the 2 most common fault codes on these machines I have listed below this post.
If the machine is still under warranty i would suggest using it normally they will repair this for free
and some of these have a recall on these machines
so i would contact the appliance center where you got this from and see if you can get it repaired ok?
"LE " persists
in washer display
Lid lock failure
Replace switch,
linkage, lock solenoid or control board.
1E persists
in washer display
Lid lock failure
Replace lid
lock switch or control board.
SOURCE: Doors wont lock. Windows
Window fuse's and relay's may be up under driver or passenger side dash or behind glove box, under the hood and even under the seats, and finally on the ends of the dash. All passenger power windows and locks are controlled thru and get power from the master control switch on the drivers door. Could be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit. Check that all switches return to neutral when released. It could also be the body control module.
SOURCE: The Driver's side door of
first make sure the bolts which hold the latch mechanism to the door are firmly screwed in. if that ain't it, remove the post which it clamps onto from the door jamb and switch it with one from a back door. close the back door firmly, lock it and never use it again. if that ain't it go to www.getsaturnparts.com and buy yourself a new door latch mechanism and pay an auto glass shop to put it in for you.
