Question about DeLonghi Pinguino PAC-290 Air Conditioner
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
This PAC was working fine, ran for about 12 hours, then I heard a click, the bottom red light came on (has a triangle with an exclamation point next to it), and the compressor shut off. I pressed the RESET button and the compressor came back on and the red light went out. This time it ran for about 3 hours, I heard the click again, the red light came on again, and the compressor shut off again. I pressed the RESET button again, but the red light stayed on and no compressor. I drained some water (not sure if I emptied all of it), but the light would not go off, and still no compressor. The unit still powers on, green and red light lit, and the fan blows air, but the compressor will not come on. BTW, I couldn't find the plastic hose that came with it, so I used some flex aluminum dryer hose to exhaust the air (got very hot).
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Posted on Sep 23, 2010
jfpogie
  • 104 Answers
SOURCE: DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Posted on Jan 20, 2008
  • 134 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Posted on Feb 14, 2009
  • 10865 Answers
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
  • 340 Answers
SOURCE: Descaler
Vinegar is the cheapest. or CLR @ home depot. Tom
Posted on Jun 18, 2009
  • 66 Answers
SOURCE: DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Posted on Feb 19, 2010
Delonghi air conditioner it has a triangle with an exclamation point inside. What does this mean?
There is a knob on the back and bottom of the air conditioner. Twist off the knob and unplug the little black plug and empty the water into a container. I had the same problem and this worked for me.
Jul 17, 2012 | DeLonghi PAC W130 Portable Air Conditioner
I have a volvo s80, a light on the dashboard has a photo of a car that is leaning inside of a triangle,what does that light mean
The "leaning triangle" light is the light signifying there is a fault with the traction system (STC) a quick scan with a scan tool will tell you exactly what the fault is.
The only other triangle light on these cars is the triangle with the circle and the exclamation point. Which is either Orange or Red depending on the severity of the issue. And what you described sounds like the STC light to me.
Hope this helps.
Sep 18, 2011 | 2001 Volvo S80
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
Warning signal
I have a yellow triangle with a ? on my dash what does this mean
May 07, 2010 | 2006 BMW 3 Series
What does the warning light - yellow circle surrounding a triangle with an exclamation point - mean? thank you
Are refer to the Brake System; in RED and YELLOW condition, continue driving cautiously:
More details about this Warning Lights you can find in the 2003 Mini Cooper - Owners Manual (page 16 and next).
I really hope helps with this (remember rated this help) Good luck.
Jan 08, 2010 | 2003 Mini Cooper
Won't connect wireless internet it is a acer one notebook...got it to work at one location and now home it hasn't worked yet...did the whole india talk for hours
Okay, there are a couple of things that might be the matter. First off, make sure there isn't a switch on the outside to turn the wireless modem on or off. Second, there should be an icon, at the bottom right of your taskbar, of a monitor with a red X next to or over it, or a picture of of same, only with a yellow triangle next to it, with an exclamation point in the middle, or the same with a little globe next to it. The first one means you are not connected, the second means limited connection, and the third means you have a connection. hover over the icon and it should tell you your connection status. If you right click on the icon, you can either check your connection status, or connect to a network. If you are not connected to a network, click Connect to a Network, and it should look for networks available. Once your computer has found a network, click on it to connect. If your wifi is a secure connection, you may need to enter a password. If you lose connection, you can right click the same icon as before, and select repair connection, or on Vista, diagnose & repair. If none of this is working, you may want to make sure that your computer hasn't got too strong a firewall set up, so that nothing may get past. Windows can sometimes be very temperamental about trying to do anything at first, until it learns how things work.
Oct 22, 2009 | Acer Aspire One PC Notebook
Facebook chat has yellow triangle with exclamation point in it???
This happens when you lose your connection, refresh the page and you should be able to continue chatting.
If this doesn't work, then facebook might be doing some maintenance work on their chat module.
Mar 26, 2009 | Facebook Computers & Internet
Fridge problem
means the temperature has gone up and freezer temperature is too high. fault should rectify itself given some time
May 11, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
DeLonghi Pinguino PAC-290 Air Conditioner Logo
2,261 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
