Question about Whirlpool LGR5636L Gas Dryer
Whirlpool LGR6634B no heat
Vent clear, electric motor runs
    Scholar:
  • 76 Answers
When you say no heat, do you meen like no heat, only blowing air or no heat as in some heat but not enough? If its compltely no heat what so ever only aor is blowing, Its is probably your thermo fuse. Disconnect power cord first. Go to the back of you dryer panel and take of all th screws around back panel that hold it up, once you take it out you will see wires and fuses....the thermo fuse is the small white skinny oval shaped fuse. i think its on a slant..bit its small white skinny ovel shaped fuse....If you have a a multi meter ohm it out. Put the meter on the ohms setting and out the 2 leads on the each of the fuse terminals. if it read "OL" you need a new thermofuse. If it reads 0.0 ohms then its good. But you dont have a meter, go ahead and change it out anyways, its probably bad. hopefully this helps
Posted on Jul 30, 2009
Whirlpool model LGB6000KQ1 electric dryer. I have to run the dryer two to three times before the clothes dry. There is a little heat, and I cleaned all the vents. Do I need a new heating element?
if the exhaust hose is clear of debris and you feel a good flow of air through it then ' Yes ' I would say that the heating element is bad.
c...
Dec 30, 2010 | Whirlpool Dryers
Extreme heat comes out from behind dryer a orange glow is in the dryer vent could this be fire
that's the glow from the heater,this is normal.the dryer should be cleaned if it's electric i would clean it every two years,you need to clean out the duct that the lint filter slides into,vac out the inside of the dryer where the motor is and disconnect the vent line from the back of the dryer and clean out the vent line,if it's a long run to the outside i use a leaf blower to blow out the vent line,make sure the outside duct is clear also.if you do this you wont have to worry about a fire,your clothes will dry on time,you'll save electricity and your dryer wont run hotter than normal and your parts in the dryer will last longer.let me know how you make out
Aug 22, 2010 | Whirlpool LER5636P Electric Dryer
Whirpool dryer 10 years old is still heating but taking very long to dry clothes. Checked dryer vent and it is clear. Will heating element help?
If your heating element is still heating up the cause lies elsewhere. Filter for dryer both at the base of dryer and filter location . If you are getting heat then airflow is the problem. how is the fan motor in front of heating element
Mar 09, 2010 | Whirlpool LER5636P Electric Dryer
My dryer stopped drying wont get hot what could be wrong?
i'd check for 220 volts fist sometimes a breaker can trip one leg letting it run but no heat, next i check for vent blockage then check thermal fuse, if fuse is blown and vent was clear is blower wheel striped, check temp dosen't go over 185 deg at discharge hose if it's going over change operating thermostat. if fuse is good check thermostats and element for continuity if good need to check for power to all above if only 120 volt bad switch in motor or timer
Jan 03, 2010 | Whirlpool GEW9250 Electric Dryer
No heat in a 1 year old Whirlpool ncabrio dryer
If there is no heat, it has nothing to do with the vent, but everything to do with the element. Yoiu either have a bad element or are not getting power to it.
Oct 05, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Loads have to run through high heat cycle twice to get completely dry. It was drying completely with one run through any cycle.
have you checked your wall vent hole and dryer vent hole to make sure they are clear?if there not it will keep the hot wet air from coming out and take forever to dry,let me know-mike
Apr 14, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool dryer not enough heat
There may very well be a clog in the vent line. Check the vent to be sure it is clear. Make sure to check the outside vent cover. Some of these vent have screen/louvers that can get clogged.
Jan 02, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LGR5636L Gas Dryer Logo
254 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
