Question about RCA RS2663 Shelf System
Cd player was working fine. the other day I go to play the cd's and it says no discs.There are the same 5 cd's in player.I took them out and put them back in,I turned it off,but it keeps showing no discs.any suggestions
This is NOT the solution to this problem. There is a way to reset the entire unit that will fix this problem. I performed this about a year ago, but have been unable to find the procedure again. When I find it I will post it. If anyone else has the "quick reset" procedure, please let us know...
Posted on Nov 28, 2009
  • 57 Answers
Could be dust or debris (pet hairs etc) on the lazer. Remove the disks and blow gently. There is a lazer cleaning disk which you could try.
Posted on Jul 29, 2009
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
How can I get my RCA 5 disc CD changer stereo to work right?
I have an RCA 5 Disc Changer, purchased at Target. The first one had a prolific issue of skipping on discs. It would play part of song on the first disc then suddenly change to the next disc. However, it did not ALWAYS do this, just sometimes, seemingly at random. Then one day, it would suddenly work just fine on all 5 discs. Eventually it simply would not play an entire song at all, so I took it back (within the time of the warranty). They had 1 of the same left on the back shelves so was able to get that one. This one started doing the exact same thing within the month. Now, it will not READ discs. It will simply read, 'Read"..and then when it comes up showing the disc number it has all zeros. I tried skipping to the next disc and then the next, and suddenly it read. That was fine for two days, then it would not even do that. I tried using compressed air inside all of the open disc drawer, and on all the discs but to no avail. Just now I tried tilting the entire unit Back at about a 30 degree angle and while in that position hit the 'disc change' button on the remote and suddenly it read. How long will this work? Have no idea. Very irritating - and it's hard to find this kind of player anymore, apart from a Component System which is a whole new playing field. Amazingly , I had bought my first changer, a 6 CD changer, cheap one at wal mart long ago and it lasted me about 10 years and never had a problem. It was a no-name brand too, I would expect better from RCA but alas, tis not the case.
Jun 05, 2014 | RCA Audio Players & Recorders
Put in clean commercial disc and get error msg "no disc" period!
Dr. OM,
Lets give it a try. The purchasedate will be 1991 (HI).
I'll suppose you allready cleaned the laserunit.
You can try to clean the laserslides, sometimes they are sticky and dry. Then the laser is not fast and precise enough to read the index of your CD.
Clean them with some alcohol on cottontips.
When they are really clean, use just a little teflonoil to make sure the laserunit slides very smoothly.
Regards,
73's Gerard
May 13, 2010 | Sony CDP-C505 5-Disc CD Changer
6 disk CD changer in 2004 Chevy Suburban
I am having the same problem with my CD changer in a 2004 Suburban. Have you found a solution yet? Chevy dealership told me that I would have to replace the radio.
Dec 31, 2009 | 2004 Chevrolet Suburban
CD PLayer no longer recognising CD RW discs
Try cleaning the discs with straight swipes, with a dry cloth, like your shirt, starting from the center and swiping outward.
Mar 01, 2009 | Sharp CD-XP5500 CD Shelf System
It wont play dvds!!! Help!!! Panasonic SC-HT520
You can try a CD/DVD Cleaner Disk ($3-$5). Some sell for $15, don't know if you'll get better results. If it doesn't work, then you have a laser alignment issue that needs calibrating. The labor is likely to cost more than a new DVD player.
Dec 28, 2008 | Panasonic SC-HT520 System
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
RCA RS2663 Shelf System Logo
272 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
