Question about GE GSS25JEMWW Side by Side
Refrigerator and freezer
Freezer or refrigerator side will not get cold. The fan in the back of the fridge is running but no cold air anywhere. There's a knob in the front like under the fridge which I turn until it clicks but still nothing happens. The compressor is really warm to touch and you can hear somrthing like it kicks in but no cold air. Please help. Hi, I have the same problem with my refrig GE TFX22CRDAWW model. recently I changed defrost time, defrost heater, and defrost thermostat but the problem is still the same not cold enough on both freezer and refrig.But I just recognized that when I turn on the refrigerator for the first two minutes it has ice started to build around a coil but after that I heard refrigerator keep click on and off in every couple minutes. Do you know what is the next step I have to do. Thank you for your help. Dan
  • learnfrig Nov 24, 2007
    First of all thank you for your time and your expert.
    The evaporator fan and compressor fan both are working. I did clean dust from underneath the refrigerator but it is not cold enough (always 40 degree in freezer).
    My guess is it may be low on refrigrant. My question for you is can I recharge the refrigant by myself. If it doable please give me some instructions how to add more freeon to compressor.
    Again, thank you for your help.
  • learnfrig Nov 26, 2007
    One last question before I call a technician, When I turn on the refrrigerator I heard the click at PTCR/Overload on the left of compresssor. When the Click on I hear the compressor start to do something but it last for less than a minute when another Click kick on but the compressor is still running. It continues doing that for a long time so I decided to turn power off. Do you thinhk something wrong with the Overload replay swicth?
    Thank you,
    Dan
    Sergeant:
    Champion:
  • 298 Answers
Is the fan behind the back panel underneath
running (condenser fan) may be dead or clogged
with something if not thats the problem if it is
running take a vac attachment and clean
the dust or blow the dust from underneath
the refrigerator (after turning it off)dont bend
anything,After verifying the condenser fan runs
and cleaning the condenser try it out
If there is no improvement and,
If the system has not been opened before I
would say there is a leak in the system
(low charge) Requires the
attention of a service person
Posted on Nov 23, 2007
  • Eugene Merritt Nov 25, 2007
    Requires proffessional equipment vac pump,pressure guages,
    filter drier has to be replaced Not doable unless you have the
    experience
    Not Doable requires proffessional equipment and experience
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Sxs fridge freezer is cold but fridge not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer side works fine. Fridge side not as cold as should be. Fan is working on freezer side
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 16, 2010 | Kenmore 44109 / 44102 Side by Side...
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
New Kennmore side by side freezer works but refrig is warm
Do you hear the fan running in the back of the compartments when either door is open? The freezer side runs the fridge side and a fan transfers the cold air from the freezer to the fridge side. If the fan does not run or there is a blockage then the fridge side will not get cold of course.
Sep 29, 2009 | Kenmore Refrigerators
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets cold...fan blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
GE GSS25JEMWW Side by Side Logo
234 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
